New version 18.0
New version 18.0
Post by Jachym » Wed May 06, 2020 1:34 pm
Hi guys,
a new version is available (18.0 Papaya). Please see the blog for more info.
nineback
Software: WeeWX
Re: New version 18.0
Post by nineback » Wed May 06, 2020 9:19 pm
I updated from 17.2 without any errors, however, the footnote at the bottom of the web page still shows Meteotemplate 17.2 Nectarine. I cleared my browser cache and it still shows 17.2. This happened on two different installations (different web addresses).
LOBWX
Station model: Ambient WS 1401-IP
Software: MeteoBridge
Post by LOBWX » Thu May 07, 2020 12:41 am
Sweet, thank you Jachym :D
MTQ
Software: WD API
Post by MTQ » Thu May 07, 2020 6:45 am
Updated and working smoothly. As always, updates are VERY easy.
Footnote at the bottom of the web page showing "18.0 Papaya".
Thank you Jachym!
MTQ
Software: WD API
Post by MTQ » Thu May 07, 2020 7:08 am
Hi again,
One issue I've seen is that the radarES block is not showing any radar info...
nineback
Software: WeeWX
Post by nineback » Thu May 07, 2020 10:13 am
Jachym replied to an email I sent:
"after each update you need to go to the Main setup and click "save" even if you do not modify anything. This triggers update of the footer and several other scripts to finalize the update."
This guidance is at the very bottom of the update instructions on the blog (below the What Is New section). I only read the Update process section. :oops:
nineback wrote: Wed May 06, 2020 9:19 pm I updated from 17.2 without any errors, however, the footnote at the bottom of the web page still shows Meteotemplate 17.2 Nectarine. I cleared my browser cache and it still shows 17.2. This happened on two different installations (different web addresses).
Jure
Station model: Froggit HP1000SE
Software: Ecowitt plugin
Post by Jure » Thu May 07, 2020 10:41 am
Thank you Jachym!
Update went without a hitch! Papaya sure tastes good! :)
Jure
John B
Post by John B » Fri May 08, 2020 1:57 am
Thanks, Jáchym.
The installation worked liked a well greased wheel.
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Fri May 08, 2020 6:15 am
Bonjour Jachym
Après quelques problèmes pour obtenir le Key.
Mise à jour parfaite et très rapide.
Prends soin de toi
Meteopomezia
Software: Wview
Post by Meteopomezia » Fri May 08, 2020 7:15 pm
Updated smoothly
everything works great
Thanks Jachym ;)
F1SKF
Station model: HP2550
Post by F1SKF » Sat May 09, 2020 12:04 pm
I want to update from version 17.2 to 18.0.
Questions :
I copy the update folder of version 18.0 instead of the update folder of version 17.2?
To launch the update I launch the file: update.php? or updateSetup.php?
Thank you.
Herve
Bonjour,
je veux mettre à jour de la version 17.2 vers 18.0.
Questions :
Je copie le dossier update de la version 18.0 à la place du dossier update de la version 17.2 ?
Pour lancer la mise à jour je lance le fichier : update.php ? ou updateSetup.php ?
Merci.
Hervé
nineback
Software: WeeWX
Post by nineback » Sat May 09, 2020 12:53 pm
F1SKF
Post by F1SKF » Sat May 09, 2020 1:40 pm
That's what i did, but:
2 - extract the package and inside you will find a folder update_18.0
I don't have a file update_18.0 !!
Screenshot 2020-05-09 at 15.39.02.png (45.28 KiB) Viewed 27403 times
Jolumarali
Software: WlIP
Post by Jolumarali » Sat May 09, 2020 2:58 pm
Bonjour
Tu installes update 18 (dézipper) dans le dossier update
et tu ouvres avec /update/update_18.0/updateTemplate.php
Une page va s'ouvrir et en bas du devrait voir succès
Avant tu ouvres panneau de configuration de meteotemplate et termine en sauvegardant (Save).
Bonne soirée
F1SKF
Post by F1SKF » Sat May 09, 2020 10:47 pm
BonjourJosé Luis,
J'avais bien compris tout çà :
" Tu installes update 18 (dézipper) dans le dossier update
Mais je n'ai pas de update 18 ni de updateTemplate.php dans le fichier meteotemplate_18.0.zip
Voila juste ce que j'ai dans le Zip de meteo template : un dossier update qui contient
Merci et bonne journée
Hervé
Screenshot 2020-05-10 at 00.39.34.png (10.01 KiB) Viewed 27393 times
F1SKF
Post by F1SKF » Sat May 09, 2020 11:00 pm
Problème résolu !
En fait j'ai Meteotemplate V8 complet et non la mise à jour !
J'ai redemandé une clé à Jachym pour télécharger la mise à jour cette fois.
Hervé
meteo88.pecouba.fr
Problem solved !
In fact I have Meteotemplate V8 complete and not the update!
I asked Jachym for a key to download the update this time.
Herve
[url] meteo88.pecouba.fr
[/ url]
Jolumarali
Software: WlIP
Post by Jolumarali » Sun May 10, 2020 7:59 am
En fait avec un peu de retard de lecture, c'est la réponse que je voulais te donner.
Bon déconfinement.
F1SKF
Post by F1SKF » Sun May 10, 2020 8:50 am
Mise à jour réussie.
Avec le bon fichier (update 18) c'est quand même mieux.
Merci pour l'aide.
Porte toi bien également.
Hervé
