Hello, I've gone through the wiki and the forum and I cannot update the template with actual data...
http://quintadashortas.byethost12.com/t ... esktop.php is the website,
Using WeatherLink and plugin, unsuccessful, cron job done...
or trying Wunderground, got this message when testing...
"Update Test
Update type tested: Weather Underground
Loading data from weatherunderground.com for station: ISOMAR3..."
Hope someone could help with some ideas, thanks in advance.
Juan
Template not updating data
juanrpaz
Re: Template not updating data
Further information
meteotemplateLive.txt updates but no data into it
"Update Test
Juan
"Update Test
Juan
- Jolumarali
- Station model: Vantage Vue
- Software: WlIP
Ola juan
com isso modificado WLIP
você me mantém informado
modelo com token
tradutor do google usado
Amizades
modelo com token
Amizades
- wlIP.zip
- (4.11 KiB) Downloaded 434 times
juanrpaz
Hola José Luis,
Thanks for the info. I have double checked the plugin configuration, which appears to be okay.
Website is at
For what I understand from the wiki, the plugin then access the api.php module, so creating the meteotemplateLive.txt and such, providing actual data to the template. This file however only updates with values=zero and only updates when I run the cronjob directly on the browser...
cronjob is
http://quintadashortas.byethost12.com/t ... ass=xxxxxx
the return in the file mtLive.txt is
{"T":0,"H":0,"P":0,"B":0,"W":0,"G":0,"R":0,"RR":0,"S":0,"UV":0,"U":1604088409,"TIN":-17.800000000000000710542735760100185871124267578125,"HIN":0,"SW":"wlIP","TTime":1604088409,"HTime":1604088409,"PTime":1604088409,"BTime":1604088409,"WTime":1604088409,"GTime":1604088409,"RTime":1604088409,"RRTime":1604088409,"STime":1604088409,"UVTime":1604088409,"UTime":1604088409,"TINTime":1604088409,"HINTime":1604088409,"SWTime":1604088409,"D":-112,"DTime":1604088409,"A":-4,"ATime":1604088409}
Any further thoughts?
Gracias, lo he escrito en inglés por si algún otro usuario tiene alguna idea.
Website is at
cronjob is
- Jolumarali
- Software: WlIP
Hola juan
dime, ¿estás usando weatherlink live o estás usando el registrador datalogger IP?
Saludo
Saludo
juanrpaz
Buen día!
Tengo la cuenta en WLLive, y un USB data logger que me proporciona los datos históricos en mi PC.
WL IP logger lo dejaron de hacer...
Saludos,
Juan
Saludos,
Juan
- Jolumarali
- Software: WlIP
Esta es la razón por la que WLIP no funciona, solo la versión v1.
Jachym está esperando la versión V2 de weatherlink Live (problema con la lluvia).
Mientras tanto, puede usar weatherdisplay, tiene funciones weatherlink Live.
Así que personalmente no puedo ayudarte más, mis habilidades son limitadas.
puede ser de ayuda en el foro.
Saludos de francia
cuidate ti y tu familia
Saludos de francia
