DegreeDays plugin - grade input with tenths
ph2
There are two small errors in the DegreeDays plugin: If the base temperature is entered with a comma, incorrect values are calculated (only the value after the comma as the base). This temperature may only be entered with a dot!; In addition, the distance between the monthly overview and the buttons “Heating Degree Days” and “Temperatures” is more than one page; i.e. it is very easy to overlook these buttons!
