Not shure if it is a problem of my installation ( meteotemplate papaya 18.0 ) but I found that both plugins refer to a non existent 'indoor' table of the database. Had to change also a few fields name ( uppercase/lowercase )
Attached the revised versions.
UPDATE
The above is not correct!
The indoorData plugin instructions ( which I didn't read, to my shame, until now ) says that you have to copy the updateIndoor.php script to the load/crons directory and set a cron job to run load/cron.php script.
If you did that you are ok with the original plugins.
If you didn't... then install the attached plugins ( you don't need the additional 'indoor' table, as the alldataExtra already has these data )
indoorData degreeDays
- indoorData_4.1.zip
- (117.76 KiB) Downloaded 540 times
- degreeDays_1.1.zip
- (69.15 KiB) Downloaded 528 times
