Hi!
Metoebridge and API: For two months now, the indoor data has only been written to the database once an hour and not every 5 minutes. The cron job runs every 5 minutes. When I check the echo output, I see that the DateTime timestamp remains unchanged for an hour. The unchanged values are not written to the database either.
In the API plugin, the values change every 10 seconds. And the file meteotemplateLive.txt is rewritten every minute with the correct new UTC time stamp.
Where can I set the data to be saved every 5 minutes?
Greetings Harald
IndoorData is only updated every hour
Re: IndoorData is only updated every hour
I don't understand completely your question. So a few questions:
a) if you check your database extra sensor data are present only at 1 hour intervals?
b) the apiViewer Plugin updates every 10 seconds?
c) the file meteotemplateLive.txt is written every minute?
d) what are the extra sensor data that should be written to the database ( Tin, Hin... )?
e) in the post title you are referring to indoorData so you are particularly interested to Tin and Hin?
f) what is the url of your site?
ph2
Thanks for the feedback. My answers as inlay:
Yes, in the indoor database only once every hour, in the alldataExtra database (with humidity, temperature indoor and extra sensor T1 (water temperature)) every 5 minutes
Yes, every 10 seconds
Yes, every minute
Humidity, temperature
Yes, humidity, temperature indoor
I'm still testing, the site is not yet official: https://www.pallausch.at/stw-wetter/tem ... esktop.php
The change took place on 1/19/21, 5:44 pm: previously the data was written to the database every 5 minutes, since then only every hour. I don't remember changing anything.
Greetings Harald
Yes, every minute
Greetings Harald
The indoor table is written by the load/crons/updateIndoor.php.
You should have a cron job that call load/cron.php ( that in turns calls all the scripts in the directory load/crons )
Maybe you changed the timing of this cron job. So you have only to verify that the cron job is called every 5 minutes or less.
You may even remove that script if you install the modified indoorData and degreeDays plugin I posted some while ago.
ph2
Thank you I know. The cron job runs every 5 minutes! As already written: When I check the echo output of the cronjob, I see that the DateTime timestamp remains unchanged for an hour. This means that the same time stamp is always entered for about an hour. And if the timestamp does not change, no new entry is made in the database.
For example:
Cronjob from 3/19/21, 00:25:00: "Loaded CRON: /xxx/template/load/crons/dailyNotificationsCron.php <br> Indoor save interval elapsed. <br> Indoor conditions being saved. <br> Using API. <br> Executed query: INSERT INTO indoor (DateTime, Tin, Hin) VALUES ('2021-03-19 00:04', 5,72) <br> Loaded CRON: / xxx / template / load / crons /updateIndoor.php <br> "
5 minutes later:
Cronjob from 3/19/21, 00:30:00: "Loaded CRON: /xxx/template/load/crons/dailyNotificationsCron.php <br> Indoor save interval elapsed. <br> Indoor conditions being saved. <br> Using API. <br> Executed query: INSERT INTO indoor (DateTime, Tin, Hin) VALUES ('2021-03-19 00:04', 5,72) <br> Loaded CRON: / xxx / template / load / crons /updateIndoor.php <br> "
The same timestamp in both jobs !!
Greetings Harald
For example:
5 minutes later:
Greetings Harald
Ok, I see
I don't know if this is important, but you have a form of caching enabled, server side.
For example I'm reloading your page:
https://www.pallausch.at/stw-wetter/tem ... teLive.txt
And I get the same result ( nothing changes, no matter how many times I repeat or how long I wait )
Have to change the url to update the page ( for example adding aaaa at the end: https://www.pallausch.at/stw-wetter/tem ... e.txt?aaaa )
But if this is the problem, you should see similar misbehaviour in all blocks/plugins that use meteotemplateLive.txt
ph2
Hello!
Thanks for the tip, it helped! Some time ago my provider set up a varnish cache that cannot be turned off. I have now set up an additional cron job with curl -X PURGE, and since then it has been updated every 5 minutes!
greetings
greetings
