Meteotemplate - process of updating
Re: Meteotemplate - process of updating
Post by alexvanuxem » Wed Aug 23, 2023 3:37 pm
Thank you!
no idea why this gone missing suddenly, maybe just me.... :roll:
milesb
Post by milesb » Thu Aug 24, 2023 5:42 am
Downloaded Update_19.0, and update completed without an error. Site seemed to be functioning without issue, but there is a problem that showed up later.
Although everything appears normal initially, specifically the current block is updating normally, I noted that in the System Data block, the next day that it was blank. I logged in as admin, and when I look at the database, there are no entries after the point that I updated my site.
Post by Jachym » Thu Aug 24, 2023 6:32 am
this is very strange. I have 3 users reporting this, others say it is fine.
I would like to know:
- which PHP version are you using
- which software do you use for the updates
milesb
Post by milesb » Thu Aug 24, 2023 10:40 am
Jachym wrote: Thu Aug 24, 2023 6:32 am Hi,
I'm using PHP 8.1
Running Weather Display Ver 10.375S148
Post by FSC830 » Thu Aug 24, 2023 10:56 am
Hi Jachym,
I have had once the same issue (please remember my mail), after replacing the API.php all was fine and database was updated again.
Post by Jachym » Thu Aug 24, 2023 5:43 pm
Hi guys,
if your template stopped updating once you updated to PHP8.x, please try replacing the api.php code with the one below, it should help.
<?php
    #   Meteotemplate
    #   http://www.meteotemplate.com
    #   Free website template for weather enthusiasts
    #   Author: Jachym
    #           Brno, Czech Republic
    #   First release: 2015
    #   v2.0    2017-04-20  Now also handle data of update programs
    #   v2.1    2017-04-24  Handling of fallen rain between 23:55 and 00:00:00
    #   v2.2    2017-07-02  Added Extra sensors; fixed bug rain at begin of day
    #   v3.0    2017-08-11  Added multipliers
    #   v3.1    2017-12-20  Discard outdated parameters; added mysql error logging
    //error_reporting(E_ALL);
    $apiLog = array();
    $rawInput = array();
    $utc = time();
    $timeId = "Time";
    if(isset($apiUpdate)){
        // api included by CUMULUS, WU, CUSTOM, NETATMO, WLIP
        $rawUpdate['SW'] = $apiUpdate;
        $apiLog['info'][] = "Handling data from ".$apiUpdate;
        // load data
        foreach ($rawUpdate as $key => $value) {
            $rawInput[$key] = $value;
            if($key == 'U'){
                $apiLog['info'][] = "update 'U' = ".$rawInput['U']." (".date("Y-m-d H:i:s",$rawInput['U']).")";
            else{
                $apiLog['info'][] = "update '".$key."' = ".$rawInput[$key];
    else{
        // api section called by http
        $base = "";
        // load main info
        require($base."config.php");
        // load dependencies
        require($base."scripts/functions.php");
        // check acces authorization
        if(isset($_GET['PASS'])){
            $password = $_GET['PASS'];
        else if(isset($_GET['PASSWORD'])){
            $password = $_GET['PASSWORD'];
        else{
            die("No password provided");
        // check if password is correct
        if($password!=$updatePassword){
            if($password==$adminPassword){ // if admin password provided accept, but notify
                echo "Authorized via admin password";
            else{
                die("Unauthorized");
        $apiLog['info'][] = "Authorized access.";
        $apiLog['info'][] = "Current date/time: ".date("Y-m-d H:i:s");
        $apiLog['info'][] = "api called by http";
        // read raw input
        if(isset($_GET)){
            foreach($_GET as $urlParameter=>$value){
                if($urlParameter!="PASSWORD" && $urlParameter!="PASS"){
                    $rawInput[$urlParameter] = $value;
                    $apiLog['info'][] = "update ".$urlParameter.": ".$value;
        else{
            // no data in api
            $apiLog['error'][] = "api: no data";
            generateAPILog();
            die("api: no data");
        // end of api section
    // common part for both:
    // apiUpdate section called by /update/update.php
    $apiLog['info'][] = "Begin of common part of api script";
    #                            HANDLING LIVE DATA
    $apiLog['info'][] = "Start handling live data";
    // Preset time of live update
    foreach ($rawInput as $key => $value) {
        $rawInput[$key.$timeId] = $utc;
    // multipliers
    if($multiplierT != 0 && isset($rawInput['T'])){
        $rawInput["T"] = $rawInput["T"] + $multiplierT;
    if($multiplierP != 0 && isset($rawInput['P'])){
        $rawInput["P"] = $rawInput["P"] + $multiplierP;
    if($multiplierW != 1 && isset($rawInput['W'])){
        $rawInput["W"] = $rawInput["W"] * $multiplierW;
    if($multiplierR != 1 && isset($rawInput['R'])){
        $rawInput["R"] = $rawInput["R"] * $multiplierR;
    if($multiplierW != 1 && isset($rawInput['G'])){
        $rawInput["G"] = $rawInput["G"] * $multiplierW;
    if($multiplierR != 1 && isset($rawInput['RR'])){
        $rawInput["RR"] = $rawInput["RR"] * $multiplierR;
    // Check if extra sensors should be loaded
    $apiLog['info'][] = "Checking if extra sensors should be logged";
    $extraSensors = array();
    if(file_exists($base."update/apiSettings.txt")){
        $extraAPIRaw = json_decode(file_get_contents($base."update/apiSettings.txt"),true);
        foreach($extraAPIRaw as $extraParam=>$extraValue){
            if($extraValue==1){
                $extraSensors[] = $extraParam;
    else{
        $apiLog['info'][] = "Extra sensor settings file not found.";
    $apiLog['info'][] = "Extra sensors data to save in db: " . implode(", ",$extraSensors);
    // read previous live data
    if(file_exists($base."meteotemplateLive.txt")){
        // get latest date from cache file
        $mtLive = file_get_contents($base."meteotemplateLive.txt");
        $liveInput = json_decode($mtLive,true);
        if(array_key_exists("R".$timeId,$liveInput)){ // check if rain is from yesterday, if so, delete it
            $dayRain = date("Ymd",$liveInput['R'.$timeId]);
            $dayNow = date("Ymd");
            if($dayRain!=$dayNow){
                unset($liveInput['R']);
                unset($liveInput['RTime']);
        foreach ($liveInput as $key => $value) {
            $pos = strpos($key,$timeId);
            if ($pos > 0) {
                // time parameter
                if($utc-$value > 600) {
                    // value more than 10 minutes ago; skip writing back
                    $apiLog['info'][] = "Variable too old, remove from meteotemplateLive.txt: ".$key.": ".date("Y-m-d H:i:s",$value);
                    $keyValue = substr($key,0,$pos);
                    // remove value and timestamp from array
                    unset($liveInput[$keyValue]);  // remove value
                    unset($liveInput[$key]);       // remove timestamp
            else {
                // value parameter
                $liveInput[$key] = $value;
    // convert UGP to P when needed
    if(isset($rawInput['UGP']) && !isset($rawInput['P'])){
        $apiLog['info'][] = "convert UGP: ".$rawInput['UGP'];
        // get station elevation from config
        // $stationElevation
        // $stationElevationUnits - m/ft
        // define constants for SLP calculations
        // convert elevation to m if in ft
        if($stationElevationUnits=="ft"){
            $elevationM = $stationElevation * 0.3048;
        else{
            $elevationM = $stationElevation;
        $apiLog['info'][] = "elevationM: ".$elevationM;
        $apiLog['info'][] = "liveInput['T']: ".$liveInput['T'];
        if(isset($liveInput['T'])){ // temperature is available, use more accurate formula
            $temperatureK = $liveInput['T'] + 273.15; // temperature in K
            $constant['g'] = 9.80665; // Earth-surface gravitational constant [m/s2]
            $constant['M'] = 0.0289644; // molar mass of dry air [kg/mol]
            $constant['R'] = 8.31447; // universal gas constant
            $partA = ($constant['g'] * $constant['M'] * $elevationM) / ($constant['R'] * $temperatureK);
            $convertedP = $rawInput['UGP'] / exp(- $partA);
            $apiLog['info'][] = "more accurate convertedP: ".$convertedP;
        else{ // temperature is N/A use less accurate formula
            $convertedP = $rawInput['UGP'] - ($elevationM/9.2);
            $apiLog['info'][] = "less accurate convertedP: ".$convertedP;
        $rawInput['P'] = (string)(round($convertedP,3));
        $rawInput['P'.$timeId] = $utc;
        $apiLog['info'][] = "calculated P: ".$rawInput['P'];
        // multiplier for converted UGP to P
    // add saved live data fields for not updated fields
        if(!isset($rawInput[$key])){
            // if live data key not present use saved live data
            // time fields ($rawInput[$key.$timeId]) will be copied too
            $apiLog['info'][] = "add live data: ".$key.": ".$value;
    // calculate dewpoint
    $rawInput['D'] = (string)dewpoint($rawInput['T'], $rawInput['H']);
    $rawInput['D'.$timeId] = $utc;
    $apiLog['info'][] = "calculated D: ".$rawInput['D'];
    // calculate apparent temp
    $rawInput['A'] = (string)apparent($rawInput['T'], $rawInput['H'], $rawInput['W'] / 3.6);
    $rawInput['A'.$timeId] = $utc;
    $apiLog['info'][] = "calculated A: ".$rawInput['A'];
    // save raw input
    $rawOutput = json_encode($rawInput,JSON_NUMERIC_CHECK);
    $apiLog['info'][] = "Save meteotemplateLive.txt: ".$rawOutput;
    file_put_contents($base."meteotemplateLive.txt",$rawOutput);
    // check we have write permissions for the cache folder and meteotemplateLive.txt
    if(!file_exists($base."meteotemplateLive.txt")){
        $apiLog['error'][] = "meteotemplateLive.txt was not created! Probably incorrect permissions for the template root folder.";
        echo "Live conditions file not created. Check permissions!";
    #                               PARSING
    $apiLog['info'][] = "Start data parsing";
    $convertUgp = false;
    // save live data fields to raw data
        $rawData[$key] = $value;
    // ESSENTIAL
    // Date and time
    $apiLog['info'][] = "Parsing date; Server time: ".date("Y-m-d H:i:s");
    $valid['date'] = true;
   if(!isset($rawData['U'])){
       $valid['date'] = false;
       $apiLog['error'][] = "No value for date specified.";
   else{
       // date must be passed as UNIX timestamp
       // checking: date must be numeric, must be after 1990 and must not be in the future
       $apiLog['info'][] = "Validating date: ".$rawData['U']." (".date("Y-m-d H:i:s",$rawData['U']).")";
       if(is_numeric($rawData['U'])){
           if($rawData['U']>631152000 && $rawData['U']<(time()+10*60)){ // 10 minutes tolerance
               $data['timestamp'] = ($rawData['U']); // also save the timestamp
               $data['date'] = date("Y-m-d H:i:s",$rawData['U']); // convert to MySQL accepted format
               $apiLog['info'][] = "Date is valid; difference with server time is ".($rawData['U'] - $utc)." s" ;
           else{
               $apiLog['error'][] = "Date is invalid; difference with server time is ".($rawData['U'] - $utc)." s";
       else{
           $apiLog['error'][] = "Date is invalid (not numeric)";
    // Parameters
    // Outside Temperature
    $apiLog['info'][] = "Parsing temperature";
    $valid['T'] = true;
    if(!isset($rawData['T'])){
        $valid['T'] = false;
        $apiLog['error'][] = "No temperature data provided.";
    else{
        $rawT = trim($rawData['T']);
        $apiLog['info'][] = "Temperature: ".$rawT." C";
        if($rawT===""){
            $apiLog['error'][] = "Temperature field blank.";
        elseif(!is_numeric($rawT)){
            $apiLog['error'][] = "Temperature is not a number.";
    // apply conversion - API uses Celsius
    if($valid['T']){
        $apiLog['info'][] = "Database units: ".$dataTempUnits;
        if($dataTempUnits!="C"){
            $rawT = convertor($rawT, "C", $dataTempUnits);
            $apiLog['info'][] = "Temperature converted to: ".$rawT." ".$dataTempUnits;
        // check limits
        $apiLog['info'][] = "Checking temperature is between limits specified in template Main settings.";
        $apiLog['info'][] = "Minimum temperature limit: ".$limitTempMin." ".$dataTempUnits;
        $apiLog['info'][] = "Maximum temperature limit: ".$limitTempMax." ".$dataTempUnits;
        if($rawT>=$limitTempMin && $rawT<=$limitTempMax){
            $apiLog['info'][] = "Temperature is OK and within the allowed limits";
            $data['T'] = $rawT;
        else{
            $apiLog['error'][] = "Temperature is outside the allowed limits.";
    // Outside Max Temperature
    $apiLog['info'][] = "Parsing maximum temperature";
    $valid['Tmax'] = true;
    if(!isset($rawData['TMX'])){
        $valid['Tmax'] = false;
        $apiLog['error'][] = "No max temperature data provided.";
    else{
        $rawTmax = trim($rawData['TMX']);
        $apiLog['info'][] = "Max Temperature: ".$rawTmax." C";
        if($rawTmax===""){
            $apiLog['error'][] = "Max Temperature field blank.";
        elseif(!is_numeric($rawTmax)){
            $apiLog['error'][] = "Max Temperature is not a number.";
    if($valid['Tmax']){
            $rawTmax = convertor($rawTmax, "C", $dataTempUnits);
            $apiLog['info'][] = "Temperature converted to: ".$rawTmax." ".$dataTempUnits;
        // check limits
        $apiLog['info'][] = "Checking max temperature is between limits specified in template Main settings.";
        if($rawTmax>=$limitTempMin && $rawTmax<=$limitTempMax){
            $apiLog['info'][] = "Max Temperature is OK and within the allowed limits";
            $data['Tmax'] = $rawTmax;
        else{
            $apiLog['error'][] = "Max Temperature is outside the allowed limits.";
    // Outside Min Temperature
    $apiLog['info'][] = "Parsing minimum temperature";
    $valid['Tmin'] = true;
    if(!isset($rawData['TMN'])){
        $valid['Tmin'] = false;
        $apiLog['error'][] = "No min temperature data provided.";
    else{
        $rawTmin = trim($rawData['TMN']);
        $apiLog['info'][] = "Min Temperature: ".$rawTmin." C";
        if($rawTmin===""){
            $apiLog['error'][] = "Min Temperature field blank.";
        elseif(!is_numeric($rawTmin)){
            $apiLog['error'][] = "Min Temperature is not a number.";
    if($valid['Tmin']){
            $rawTmin = convertor($rawTmin, "C", $dataTempUnits);
            $apiLog['info'][] = "Temperature converted to: ".$rawTmin." ".$dataTempUnits;
        // check limits
        $apiLog['info'][] = "Checking min temperature is between limits specified in template Main settings.";
        if($rawTmin>=$limitTempMin && $rawTmin<=$limitTempMax){
            $apiLog['info'][] = "Min Temperature is OK and within the allowed limits";
            $data['Tmin'] = $rawTmin;
        else{
            $apiLog['error'][] = "Min Temperature is outside the allowed limits.";
    // Humidity
    $apiLog['info'][] = "Parsing humidity";
    $valid['H'] = true;
    if(!isset($rawData['H'])){
        $valid['H'] = false;
        $apiLog['error'][] = "No humidity data provided.";
    else{
        $rawH = trim($rawData['H']);
        $apiLog['info'][] = "Humidity: ".$rawH." percent";
        if($rawH===""){
            $apiLog['error'][] = "Humidity field blank.";
        elseif(!is_numeric($rawH)){
            $apiLog['error'][] = "Humidity is not a number.";
    if($valid['H']){
        // discard nonsense
        if($rawH<0 && $rawH>100){
            $apiLog['error'][] = "Humidity is outside sensible range (0-100%).";
        else{
            // check limits from main settings
            $apiLog['info'][] = "Checking humidity is between limits specified in template Main settings.";
            $apiLog['info'][] = "Minimum humidity limit: ".$limitHumidityMin." %";
            $apiLog['info'][] = "Maximum humidity limit: ".$limitHumidityMax." %";
            if($rawH>=$limitHumidityMin && $rawH<=$limitHumidityMax){
                $apiLog['info'][] = "Humidity is OK and within the allowed limits";
                $data['H'] = $rawH;
            else{
                $apiLog['error'][] = "Humidity is outside the allowed limits.";
    // Wind Speed
    $apiLog['info'][] = "Parsing wind speed";
    $valid['W'] = true;
    if(!isset($rawData['W'])){
        $valid['W'] = false;
        $apiLog['error'][] = "No wind speed data provided.";
    else{
        $rawW = trim($rawData['W']);
        $apiLog['info'][] = "Wind speed: ".$rawW." kmh";
        if($rawW===""){
            $apiLog['error'][] = "Wind speed field blank.";
        elseif(!is_numeric($rawW)){
            $apiLog['info'][] = "Wind speed is not a number.";
    // apply conversion - API uses km/h
    if($valid['W']){
        $apiLog['info'][] = "Database wind speed units: ".$dataWindUnits;
        if($dataWindUnits!="kmh"){
            $rawW = convertor($rawW, "kmh", $dataWindUnits);
            $apiLog['info'][] = "Wind speed  converted to: ".$rawW." ".$dataWindUnits;
        // discard nonsense
        if($rawW<0){
            $apiLog['error'][] = "Wind speed cannot be negative.";
        else{
            // check limits
            $apiLog['info'][] = "Checking wind speed is between limits specified in template Main settings.";
            $apiLog['info'][] = "Minimum wind speed limit: ".$limitWindMin." ".$dataWindUnits;
            $apiLog['info'][] = "Maximum wind speed limit: ".$limitWindMax." ".$dataWindUnits;
            if($rawW>=$limitWindMin && $rawW<=$limitWindMax){
                $apiLog['info'][] = "Wind speed is OK and within the allowed limits";
                $data['W'] = $rawW;
            else{
                $apiLog['error'][] = "Wind speed is outside the allowed limits.";
    // Wind Gust
    $apiLog['info'][] = "Parsing wind gust";
    $valid['G'] = true;
    if(!isset($rawData['G'])){
        $valid['G'] = false;
        $apiLog['error'][] = "No wind gust data provided.";
    else{
        $rawG = trim($rawData['G']);
        $apiLog['info'][] = "Wind gust: ".$rawG." kmh";
        if($rawG===""){
            $apiLog['error'][] = "Wind gust field blank.";
        elseif(!is_numeric($rawG)){
            $apiLog['error'][] = "Wind gust is not a number.";
    if($valid['G']){
        $apiLog['info'][] = "Database wind units: ".$dataWindUnits;
            $rawG = convertor($rawG, "kmh", $dataWindUnits);
            $apiLog['info'][] = "Wind gust  converted to: ".$rawG." ".$dataWindUnits;
        // discard nonsense
        if($rawG<0){
            $apiLog['error'][] = "Wind gust cannot be negative.";
        else{
            // check limits
            $apiLog['info'][] = "Checking wind gust is between limits specified in template Main settings.";
            $apiLog['info'][] = "Minimum wind gust limit: ".$limitWindMin." ".$dataWindUnits;
            $apiLog['info'][] = "Maximum wind gust limit: ".$limitWindMax." ".$dataWindUnits;
            if($rawG>=$limitWindMin && $rawG<=$limitWindMax){
                $apiLog['info'][] = "Wind gust is OK and within the allowed limits";
                $data['G'] = $rawG;
            else{
                $apiLog['error'][] = "Wind gust is outside the allowed limits.";
    // Wind direction (bearing)
    $apiLog['info'][] = "Parsing wind direction";
    $valid['B'] = true;
    if(!isset($rawData['B'])){
        $valid['B'] = false;
        $apiLog['error'][] = "No wind direction data provided.";
    else{
        $rawB = trim($rawData['B']);
        $apiLog['info'][] = "Wind direction: ".$rawB." degrees";
        if($rawB===""){
            $apiLog['error'][] = "Wind direction field blank.";
        elseif(!is_numeric($rawB)){
            $apiLog['error'][] = "Wind direction is not a number.";
    if($valid['B']){
        // discard nonsense
        if($rawB<0 && $rawB>360){
            $apiLog['error'][] = "Wind direction is outside sensible range (0-360 degrees).";
        else{
            $apiLog['info'][] = "Wind direction is OK and within the allowed limits";
            $data['B'] = $rawB;
    // Precipitation
    $apiLog['info'][] = "Parsing daily cumulative precipitation";
    $valid['R'] = true;
    if(!isset($rawData['R'])){
        $valid['R'] = false;
        $apiLog['error'][] = "No precipitation data provided.";
    else{
        $rawR = trim($rawData['R']);
        $apiLog['info'][] = "Precipitation: ".$rawR." mm";
        if($rawR===""){
            $apiLog['error'][] = "Precipitation field blank.";
        elseif(!is_numeric($rawR)){
            $apiLog['error'][] = "Precipitation is not a number.";
    // apply conversion - API uses mm
    if($valid['R']){
        $apiLog['info'][] = "Database precipitation units: ".$dataRainUnits;
        if($dataRainUnits!="mm"){
            $rawR = convertor($rawR, "mm", $dataRainUnits);
            $apiLog['info'][] = "Precipitation  converted to: ".$rawR." ".$dataRainUnits;
        // discard nonsense
        if($rawR<0){
            $apiLog['error'][] = "Precipitation cannot be negative.";
        else{
            // check limits
            $apiLog['info'][] = "Checking precipitation is between limits specified in template Main settings.";
            $apiLog['info'][] = "Minimum precipitation limit: ".$limitRainMin." ".$dataRainUnits;
            $apiLog['info'][] = "Maximum precipitation limit: ".$limitRainMax." ".$dataRainUnits;
            if($rawR>=$limitRainMin && $rawR<=$limitRainMax){
                $apiLog['info'][] = "Precipitation is OK and within the allowed limits";
                $data['R'] = $rawR;
            else{
                $apiLog['error'][] = "Precipitation is outside the allowed limits.";
    // Rain rate
    $apiLog['info'][] = "Parsing rain rate";
    $valid['RR'] = true;
    if(!isset($rawData['RR'])){
        $valid['RR'] = false;
        $apiLog['error'][] = "No rain rate data provided.";
    else{
        $rawRR = trim($rawData['RR']);
        $apiLog['info'][] = "Rain rate: ".$rawRR." mm/h";
        if($rawRR===""){
            $apiLog['error'][] = "Rain rate field blank.";
            $apiLog['error'][] = "Rain rate is not a number.";
    // apply conversion - API uses mm/h
    if($valid['RR']){
        $apiLog['info'][] = "Database rain units: ".$dataRainUnits."/h";
            $rawRR = convertor($rawRR, "mm", $dataRainUnits);
            $apiLog['info'][] = "Rain rate  converted to: ".$rawRR." ".$dataRainUnits."/h";
        // discard nonsense
        if($rawRR<0){
            $apiLog['error'][] = "Rain rate cannot be negative.";
        else{
            // check limits
            $apiLog['info'][] = "Checking rain rate is between limits specified in template Main settings.";
            $apiLog['info'][] = "Minimum rain rate limit: ".$limitRainRateMin." ".$dataRainUnits."/h";
            $apiLog['info'][] = "Maximum rain rate limit: ".$limitRainRateMax." ".$dataRainUnits."/h";
            if($rawRR>=$limitRainRateMin && $rawRR<=$limitRainRateMax){
                $apiLog['info'][] = "Rain rate is OK and within the allowed limits";
                $data['RR'] = $rawRR;
            else{
                $apiLog['error'][] = "Rain rate is outside the allowed limits.";
    // Solar radiation
    $valid['S'] = true;
    if($solarSensor){
        $apiLog['info'][] = "Parsing solar radiation";
        if(!isset($rawData['S'])){
            $valid['S'] = false;
            $apiLog['error'][] = "No solar radiation data provided.";
        else{
            $rawS = trim($rawData['S']);
            $apiLog['info'][] = "Solar radiation: ".$rawS." w/m2";
            if($rawS===""){
                $apiLog['error'][] = "Solar radiation field blank.";
            elseif(!is_numeric($rawS)){
                $apiLog['error'][] = "Solar radiation is not a number.";
        if($valid['S']){
            // discard nonsense
            if($rawS<0){
                $apiLog['error'][] = "Solar radiation cannot be negative.";
            else{
                $apiLog['info'][] = "Checking solar radiation is between limits specified in template Main settings.";
                $apiLog['info'][] = "Minimum solar radiation limit: ".$limitSolarMin." W/m2";
                $apiLog['info'][] = "Maximum solar radiation limit: ".$limitSolarMax." W/m2";
                if($rawS>=$limitSolarMin && $rawS<=$limitSolarMax){
                    $apiLog['info'][] = "Solar radiation is OK and within the allowed limits";
                    $data['S'] = $rawS;
                else{
                    $apiLog['error'][] = "Solar radiation is outside the allowed limits.";
    else{
        $apiLog['info'][] = "Solar radiation sensor disabled in Main settings - skipping.";
    // EXTRA SENSORS
    // Now parse extra sensors
    if(count($extraSensors)>0){
        $extraQueryParams = array();
        $extraQueryValues = array();
         $apiLog['info'][] = "Now parsing extra sensors.";
         foreach($extraSensors as $extraSensor){
             if($extraSensor == "TIN"){
                 $thisSensorName = "indoor temperature";
                 $thisSensorLimits = array(1,50);
                 $thisSensorUnits = "deg C";
                 $thisSensorDecimals = 1;
             if($extraSensor == "HIN"){
                 $thisSensorName = "indoor humidity";
                 $thisSensorLimits = array(0.01,100);
                 $thisSensorUnits = "%";
             if($extraSensor == "SN"){
                 $thisSensorName = "daily snowfall";
                 $thisSensorLimits = array(0,5000);
                 $thisSensorUnits = "mm";
                 $thisSensorDecimals = 0;
             if($extraSensor == "SD"){
                 $thisSensorName = "snow depth";
                 $thisSensorLimits = array(0,10000);
             if($extraSensor == "NL"){
                 $thisSensorName = "noise level";
                 $thisSensorLimits = array(0,200);
                 $thisSensorUnits = "dB";
             if($extraSensor == "L"){
                 $thisSensorName = "lightning";
                 $thisSensorLimits = array(0,1000);
                 $thisSensorUnits = "";
             if($extraSensor == "SS"){
                 $thisSensorName = "sunshine";
                 $thisSensorLimits = array(0,24);
                 $thisSensorUnits = "h";
             if($extraSensor == "UV"){
                 $thisSensorName = "UV";
                 $thisSensorLimits = array(0,20);
             //$for($g=1;$g<=4;$g++){
                if($extraSensor == "T".$g){
                    $thisSensorName = "extra temperature sensor ".$g;
                    $thisSensorLimits = array(-60,60);
                if($extraSensor == "H".$g){
                    $thisSensorName = "extra humidity sensor ".$g;
                if($extraSensor == "TS".$g){
                    $thisSensorName = "soil temperature sensor ".$g;
                    $thisSensorLimits = array(-60,80);
                if($extraSensor == "SM".$g){
                    $thisSensorName = "soil moisture sensor ".$g;
                    $thisSensorLimits = array(0.01,200);
                if($extraSensor == "LT".$g){
                    $thisSensorName = "leaf temperature sensor ".$g;
                if($extraSensor == "LW".$g){
                    $thisSensorName = "leaf wetness sensor ".$g;
                    $thisSensorLimits = array(0,15);
                if($extraSensor == "CO2_".$g){
                    $thisSensorName = "CO2 sensor ".$g;
                    $thisSensorLimits = array(300,600);
                    $thisSensorUnits = "ppm";
                if($extraSensor == "CO_".$g){
                    $thisSensorName = "CO sensor ".$g;
                    $thisSensorLimits = array(0.1,50);
                if($extraSensor == "NO2_".$g){
                    $thisSensorName = "NO2 sensor ".$g;
                    $thisSensorLimits = array(0,10);
                if($extraSensor == "SO2_".$g){
                    $thisSensorName = "SO2 sensor ".$g;
                    $thisSensorUnits = "ppb";
                if($extraSensor == "O3_".$g){
                    $thisSensorName = "O3 sensor ".$g;
                    $thisSensorLimits = array(0,100);
                if($extraSensor == "PP".$g){
                    $thisSensorName = "particulate pollution ".$g;
                    $thisSensorUnits = "ug/m3";
             if(isset($rawData[$extraSensor])){
                $thisSensorVal = $rawData[$extraSensor];
                $apiLog['info'][] = "Sensor ".$thisSensorName." raw value: " . $thisSensorVal . " " . $thisSensorUnits;
                $apiLog['info'][] = "Limits for this sensor: " . $thisSensorLimits[0] ." to " . $thisSensorLimits[1];
                if($thisSensorVal >= $thisSensorLimits[0] && $thisSensorValue <= $thisSensorLimits[1] && is_numeric($thisSensorVal)){
                    $apiLog['info'][] = "Sensor data within acceptable limits.";
                    $extraQueryParams[] = $extraSensor;
                    $extraQueryValues[] = number_format($thisSensorVal, $thisSensorDecimals, ".", "");
                else{
                    $apiLog['info'][] = "Sensor data outside acceptable limits or value invalid.";
             else{
                 $apiLog['info'][] = "Sensor: ".$thisSensorName." not found in API file, skipping...";
    else{
         $apiLog['info'][] = "No extra sensors set to log to extra alldata table.";
    // Create/load cache file
    // first check how old the cache is, if it is older than 30 minutes delete it to prevent averaging current values with very old values when station offline
    if(file_exists($base."cache/apiCache.txt")){
        $cacheRaw = file_get_contents($base."cache/apiCache.txt");
        $cache = json_decode($cacheRaw,true);
        $latestCacheDate = $cache['timestamp'][count($cache['timestamp'])-1];
        if (time()-$latestCacheDate > 60 * 30) {
            unlink($base."cache/apiCache.txt");
            $apiLog['info'][] = "Cache file is over 30 minutes old, deleting it.";
    // cache file exists - i.e. it is valid, load it
        $apiLog['info'][] = "Cached data loaded from cache/apiCache.txt.";
    // cache file does not exist, create empty file
    else{
        $cache = array();
        $apiLog['info'][] = "No cache file found, create empty file.";
    // Check for partial data
    // Check for partial data in cache when data is not present
    $validCachedT = false;
        // use cached data instead when present
        if(count($cache['T']) > 0) {
            $T = $cache['T'][count($cache['T'])-1];
            $validCachedT = true;
            $apiLog['info'][] = "Use cached Temperature for calculations: ".$T;
    else {
        if($valid['T']) {
            $T = $data['T'];
    $validCachedH = false;
        if(count($cache['H']) > 0) {
            $H = $cache['H'][count($cache['H'])-1];
            $validCachedH = true;
            $apiLog['info'][] = "Use cached Humidity for calculations: ".$H;
    else {
        if($valid['H']) {
            $H = $data['H'];
    $validCachedW = false;
        if(count($cache['W']) > 0) {
            $W = $cache['W'][count($cache['W'])-1];
            $validCachedW = true;
            $apiLog['info'][] = "Use cached Wind for calculations: ".$W;
    else {
        if($valid['W']) {
            $W = $data['W'];
    //  Unadjusted gauge pressure
    if(isset($rawData['UGP']) && !isset($rawData['P'])){
        $convertUgp = true;
        $apiLog['info'][] = "convert UGP: ".$rawData['UGP'];
        else{
        if($valid['T'] || $validCachedT){ // temperature is available, use more accurate formula
            $apiLog['info'][] = "T: ".$T;
            $temperatureK = $T + 273.15; // temperature in K
            $convertedP = $rawData['UGP'] / exp(- $partA);
            $rawData['P'] = (string)(round($convertedP,3));
        else{ // temperature is N/A skip calculation
            $apiLog['info'][] = "No valid temp, skip less accurate calculation ";
    // Barometric pressure
    $apiLog['info'][] = "Parsing pressure";
    $valid['P'] = true;
    if(!isset($rawData['P'])){
        $valid['P'] = false;
        $apiLog['error'][] = "No pressure data provided.";
    else{
        $rawP = trim($rawData['P']);
        $apiLog['info'][] = "Pressure: ".$rawP." hpa";
        if($rawP===""){
            $apiLog['error'][] = "Pressure field blank.";
        elseif(!is_numeric($rawP)){
            $apiLog['error'][] = "Pressure is not a number.";
    // apply conversion - API uses hectopascals
    if($valid['P']){
        $apiLog['info'][] = "Database pressure units: ".$dataPressUnits;
        if($dataPressUnits!="hpa"){
            $rawP = convertor($rawP, "hpa", $dataPressUnits);
            $apiLog['info'][] = "Pressure  converted to: ".$rawP." ".$dataPressUnits;
        // check limits
        $apiLog['info'][] = "Checking pressure is between limits specified in template Main settings.";
        $apiLog['info'][] = "Minimum pressure limit: ".$limitPressureMin." ".$dataPressUnits;
        $apiLog['info'][] = "Maximum pressure limit: ".$limitPressureMax." ".$dataPressUnits;
        if($rawP>=$limitPressureMin && $rawP<=$limitPressureMax){
            $apiLog['info'][] = "Pressure is OK and within the allowed limits";
            $data['P'] = $rawP;
            $apiLog['info'][] = "Pressure is valid.";
        else{
            $apiLog['error'][] = "Pressure is outside the allowed limits.";
    // Calculations
    // Dew point
    // essential: valid temperature and valid humidity
    $valid['D'] = true;
    if(($valid['T'] || $validCachedT) && ($valid['H'] || $validCachedH)){
        // convert temperature to Celsius if necessary
        if($dataTempUnits=="F"){
            $temperatureC = convertor($T,"F","C");
        else{
            $temperatureC = $T;
        $rawDCelsius = dewpoint($temperatureC, $H);
        // convert back to Farenheit if necessary
            $rawD = convertor($rawDCelsius,"C","F");
        else{
            $rawD = $rawDCelsius;
        $apiLog['info'][] = "Calculated dew point: ".$rawD." ".$dataTempUnits;
        // just do some basic checking, but should be ok since T and H both valid
        if(is_numeric($rawD) && $rawD!=="" && $rawD!=null && $rawD>-100 && $rawD<200){
            $data['D'] = $rawD;
            $apiLog['info'][] = "Dew point ok.";
        else{
            $apiLog['error'][] = "There is some problem with the calculated dew point value. Ignored.";
            $valid['D'] = false;
    else{
        $apiLog['info'][] = "Temperature, humidity or both are not valid and dew point calculation is therefore skipped.";
    // Apparent Temperature
    // essential: valid temperature, valid humidity and valid wind speed
    $valid['A'] = true;
    if(($valid['T'] || $validCachedT) && ($valid['H'] || $validCachedH) && ($valid['W'] || $validCachedW)){
        else{
            $temperatureC = $T;
        if($dataWindUnits!="ms"){
            $windMS = convertor($W,$dataWindUnits,"ms");
        else{
            $windMS = $W;
        $rawACelsius = apparent($temperatureC, $H, $windMS);
            $rawA = convertor($rawACelsius,"C","F");
        else{
            $rawA = $rawACelsius;
        $apiLog['info'][] = "Calculated apparent temperature: ".$rawA." ".$dataTempUnits;
        // just do some basic checking, but should be ok since T, H and W both valid
        if(is_numeric($rawA) && $rawA!=="" && $rawA!=null && $rawA>-100 && $rawA<200){
            $data['A'] = $rawA;
            $apiLog['info'][] = "Apparent temperature ok.";
        else{
            $apiLog['error'][] = "There is some problem with the calculated apparent temperature value. Ignored.";
            $valid['A'] = false;
    else{
        $apiLog['info'][] = "Temperature, humidity, wind speed or their combination are not valid and apparent temperature calculation is therefore skipped.";
    // Check db update / update db
    $dbInterval = 300;
    // check if cache file contain a record
    if(isset($cache['timestamp']) && is_array($cache['timestamp'])){
        if(count($cache["timestamp"]) > 0) {
            // timeForUpdate calculated from timestamp of first cached data
            $checkTimestamp = $cache["timestamp"][0];
            $apiLog['info'][] = "End time for database update based on timestamp of first cache data: ".date("Y-m-d H:i:s",$checkTimestamp);
        else {
            // timeForUpdate calculated from timestamp of current data
            $checkTimestamp = $data['timestamp'];
            $apiLog['info'][] = "End time for database update based on timestamp of current data: ".date("Y-m-d H:i:s",$checkTimestamp);
    else {
    if($checkTimestamp % $dbInterval == 0) {
        $timeForUpdate = $checkTimestamp;  // $checkTimestamp is equal to end time of current archive period
    else {
        $timeForUpdate = floor($checkTimestamp / $dbInterval) * $dbInterval + $dbInterval;  // end time of current archive period
    $apiLog['info'][] = "Rounded end time for database update: ".date("Y-m-d H:i:s",$timeForUpdate);
    $updateTime = false;
    if($data['timestamp'] >= $timeForUpdate){
        $updateTime = true;
    if($data['timestamp'] == $timeForUpdate){
        // addDataToCache - current record belongs to the current archive set
        // Add current data set to cache
        // only do something if we have a valid date
        if($valid['date']){
            // add current data set to either empty cache file or add to existing cache
            $cache['timestamp'][] = $data['timestamp'];
            $cache['date'][] = $data['date'];
            if($valid['T']){
                $cache['T'][] = $data['T'];
            if($valid['Tmax']){
                $cache['Tmax'][] = $data['Tmax'];
            if($valid['Tmin']){
                $cache['Tmin'][] = $data['Tmin'];
            if($valid['H']){
                $cache['H'][] = $data['H'];
            if($valid['P']){
                $cache['P'][] = $data['P'];
            if($valid['W']){
                $cache['W'][] = $data['W'];
            if($valid['G']){
                $cache['G'][] = $data['G'];
            if($valid['B']){
                $cache['B'][] = $data['B'];
            if($valid['R']){
                // rain is cumulative, yet we cache for newDay checks
                $cache['R'][] = $data['R'];
            if($valid['RR']){
                $cache['RR'][] = $data['RR'];
            if($valid['S']){
                $cache['S'][] = $data['S'];
            if($valid['D']){
                $cache['D'][] = $data['D'];
            if($valid['A']){
                $cache['A'][] = $data['A'];
            // extra parameters
            if(count($extraQueryParams)>0){
                for($j = 0; $j < count($extraQueryParams); $j++){
                    $cache[$extraQueryParams[$j]][] = $extraQueryValues[$j];
    // if time for update, do the update
    if($updateTime){
        $apiLog['info'][] = "Time to update the database, preparing query.";
        // create the column name array for db and values array and insert date
        $db['parameters'][] = "DateTime";
        $firstCacheDate = $cache['timestamp'][0];
        $lastCacheDate = $cache['timestamp'][count($cache['timestamp'])-1];
        $apiLog['info'][] = "Timestamp first cached record: ".date("Y-m-d H:i:s",$firstCacheDate);
        $apiLog['info'][] = "Timestamp last cached record: ".date("Y-m-d H:i:s",$lastCacheDate);
        $apiLog['info'][] = "Timestamp last received record: ".date("Y-m-d H:i:s",$data['timestamp']);
        $apiLog['info'][] = "Timestamp new database record: ".date("Y-m-d H:i:s",$timeForUpdate);
        // check if this update is at 00:00:00
        $dayUpdateMin1 = date("Ymd",$timeForUpdate-1);
        $dayUpdate = date("Ymd",$timeForUpdate);
        if($dayUpdateMin1!=$dayUpdate){
           // start of a new day at 00:00:00
           $newDay = true;
        else {
           $newDay = false;
        $db['fields'][] = "'".date("Y-m-d H:i:s",$timeForUpdate)."'";
        // average temperature
        if(isset($cache['T'])){
            $db['parameters'][] = "T";
            // take temperature average and convert to db units
            $rawValue = array_sum($cache['T'])/count($cache['T']);
            $db['fields'][] = number_format($rawValue,1,".","");
        // maximum temperature
        if(isset($cache['Tmax'])){
            $db['parameters'][] = "Tmax";
            // take maximum temperature and convert to db units
            $rawValue = max($cache['Tmax']);
        else{ // if Tmax is not available see if T is and if so, use that
                // take maximum and convert to db units
                $rawValue = max($cache['T']);
        // minimum temperature
        if(isset($cache['Tmin'])){
            $db['parameters'][] = "Tmin";
            // take minimum temperature and convert to db units
            $rawValue = min($cache['Tmin']);
        else{ // if Tmin is not available see if T is and if so, use that
                // take minimum and convert to db units
                $rawValue = min($cache['T']);
        // relative humidity
        if(isset($cache['H'])){
            $db['parameters'][] = "H";
            // take humidity average
            $rawValue = array_sum($cache['H'])/count($cache['H']);
        // barometric pressure
        // determine necessary number of decimal places for pressure
        if($dataPressUnits=="inhg"){
            $decimalsP = 2;
        else{
            $decimalsP = 1;
        if(isset($cache['P'])){
            $db['parameters'][] = "P";
            // take pressure average
            $rawValue = array_sum($cache['P'])/count($cache['P']);
            $db['fields'][] = number_format($rawValue,$decimalsP,".","");
        // wind speed
        if(isset($cache['W'])){
            $db['parameters'][] = "W";
            // take wind average
            $rawValue = array_sum($cache['W'])/count($cache['W']);
        // wind gust
        if(isset($cache['G'])){
            $db['parameters'][] = "G";
            // take wind gust maximum
            $rawValue = max($cache['G']);
        else{
           // no gust data cached, take max wind speed instead
               // take wind total
               $rawValue = max($cache['W']);
        // wind bearing
        if(isset($cache['B'])){
            $db['parameters'][] = "B";
            // take wind bearing average
            $rawValue = avgWindUpdate($cache['B']);
            $db['fields'][] = number_format($rawValue,0,".","");
        // precipitation
        // determine necessary number of decimal places for precipitation
        if($dataRainUnits=="in"){
            $decimalsR = 2;
        else{
            $decimalsR = 1;
        if(isset($cache['R'])){
            $db['parameters'][] = "R";
            // take cumulative daily rain and round it to the desired number of decimals
            // use max value for check and update of last days registration
            $maxRain = number_format(max($cache['R']),$decimalsR,".","");
            // use last value for other periods
            $currentRain = number_format($cache['R'][count($cache['R'])-1],$decimalsR,".","");
            // check if newDay
            if($newDay){
                $apiLog['info'][] = "First database record in new day; check rain values";
                $previousRain = "";
                // read previous rain from database
                $queryRain = "SELECT DateTime, R FROM alldata ORDER BY DateTime DESC LIMIT 1";
                $thisQuery = mysqli_query($con,$queryRain);
                if(!$thisQuery){
                    $apiLog['error'][] = "Meteotemplate MySQL Error: ".mysqli_error($con)." with query: ".$queryRain;
                else{
                    while($row = mysqli_fetch_array($thisQuery)){
                        // the previous daily rain is already rounded to the desired number of decimals
                        $previousRain = $row['R'];
                        $apiLog['info'][] = "previous rain=".number_format($previousRain,$decimalsR,".","")." maxRain=".number_format($maxRain,$decimalsR,".","");
                        if($previousRain != "" && $maxRain > $previousRain){
                            // save rain during last (5-minute) period of the day
                            $lastRain = $maxRain - $previousRain;
                            $apiLog['info'][] = "Last rain of this day=".number_format($lastRain,$decimalsR,".","");
                            $previousDate = $row['DateTime'];
                            $newQuery = "UPDATE alldata SET R=".$maxRain." WHERE DateTime='".$previousDate."'";
                            $otherQuery = mysqli_query($con,$newQuery);
                            if(!$otherQuery){
                                $apiLog['error'][] = "Meteotemplate MySQL Error: ".mysqli_error($con)." with query: ".$newQuery;
                            else{
                                $apiLog['info'][] = "The database is updated with the following query: ".$newQuery;
                        // reset total rain at start of new day
                        $currentRain = 0.0;
                        $apiLog['info'][] = "Reset rain at start of new day=".number_format($currentRain,$decimalsR,".","");
            else{
                $apiLog['info'][] = "No new day, currentRain=".number_format($currentRain,$decimalsR,".","");
            $db['fields'][] = number_format($currentRain,$decimalsR,".","");
        // rain rate
        if(isset($cache['RR'])){
            $db['parameters'][] = "RR";
            // take rain rate average or maximum based on template settings
            if($apiRRCalculation == "max"){
                $rawValue = max($cache['RR']);
            else{
                $rawValue = array_sum($cache['RR'])/count($cache['RR']);
            $db['fields'][] = number_format($rawValue,$decimalsR,".","");
        // solar radiation
        if($solarSensor){
            if(isset($cache['S'])){
                $db['parameters'][] = "S";
                // take solar radiation average
                $rawValue = array_sum($cache['S'])/count($cache['S']);
        // dew point
        if(isset($cache['D'])){
            $db['parameters'][] = "D";
            // take dew point average
            $rawValue = array_sum($cache['D'])/count($cache['D']);
        // apparent temperature
        if(isset($cache['A'])){
            $db['parameters'][] = "A";
            // take apparent temperature average
            $rawValue = array_sum($cache['A'])/count($cache['A']);
        // calculations
        $finalExtraParams = array();
        $finalExtraValues = array();
                if(isset($cache[$extraSensor])){
                    $finalExtraParams[] = $extraSensor;
                    $thisExtraVal = array_sum($cache[$extraSensor])/count($cache[$extraSensor]);
                    $finalExtraValues[] = $thisExtraVal;
        // UPDATE!
        // Check database connection
        if (!$con) {
            $apiLog['error'][] = "Unable to connect to MySQL";
        $query = "
            INSERT INTO alldata
            (".implode(',',$db['parameters']).")
            values (".implode(',',$db['fields'])."
        $thisQuery = mysqli_query($con,$query);
        if(!$thisQuery){
            $apiLog['error'][] = "Meteotemplate MySQL Error: ".mysqli_error($con)." with query: ".$query;
        else{
            $apiLog['info'][] = "The database is updated with the following query: ".$query;
        if(date("H")==0 && date("i") <= 10){
            $thisQuery = mysqli_query($con,"ALTER TABLE alldata ORDER BY DateTime");
            if(!$thisQuery){
                $apiLog['error'][] = "Meteotemplate MySQL Error: ".mysqli_error($con)." with query: ALTER TABLE alldata ORDER BY DateTime";
        // perform query to alldataExtra if some params are available
        if(count($finalExtraParams)>0){
            $finalExtraParams[] = "DateTime";
            $finalExtraValues[] = "'".date("Y-m-d H:i:s",$timeForUpdate)."'";
            $apiLog['info'][] = "Preparing extra sensor query...";
            $queryExtra = "
                INSERT INTO alldataExtra
                (".implode(',',$finalExtraParams).")
                values (".implode(',',$finalExtraValues).")
            $thisQuery = mysqli_query($con,$queryExtra);
            if(!$thisQuery){
            else{
                $apiLog['info'][] = "The extra database table is updated with the following query: ".$queryExtra;
            // only do this at 0:00-0:10
                $thisQuery = mysqli_query($con,"ALTER TABLE alldataExtra ORDER BY DateTime");
                if(!$thisQuery){
                    $apiLog['error'][] = "Meteotemplate MySQL Error: ".mysqli_error($con)." with query: ALTER TABLE alldataExtra ORDER BY DateTime";
        // save latest results of cache and log
        file_put_contents($base."cache/latestApiCache.txt",json_encode($cache));
        if(!file_exists($base."cache/latestApiCache.txt")){
            $apiLog['error'][] = "cache/latestApiCache.txt was not created! Probably incorrect permissions on the cache folder.";
        // delete cache
        $apiLog['info'][] = "Cache file deleted.";
        if($data['timestamp'] > $timeForUpdate){
            // addDataToCache - current record belongs to the next archive set
            $cache = array();
            if($valid['date']){
                if($valid['T']){
                if($valid['Tmax']){
                if($valid['Tmin']){
                if($valid['H']){
                if($valid['P']){
                if($valid['W']){
                if($valid['G']){
                if($valid['B']){
                if($valid['R']){
                if($valid['RR']){
                if($valid['S']){
                if($valid['D']){
                if($valid['A']){
                // extra sensors
            $apiLog['info'][] = "Saving first new data to cache/apiCache.txt, timestamp=".date("Y-m-d H:i:s",$data['timestamp']);
            file_put_contents($base."cache/apiCache.txt",json_encode($cache));
        // create API update log file
        $updateLog = "";
        foreach($apiLog['info'] as $info){
            $updateLog .= $info."\n\r";
        $updateLog .= "\n\rERRORS:\n\r";
        if(isset($apiLog['error'])){
            foreach($apiLog['error'] as $error){
                $updateLog .= $error."\n\r";
        file_put_contents($base."cache/latestApiLog.txt",$updateLog);
    // not yet time for update - just save updated cache file
    else{
        if($valid['date']){
            if($valid['T']){
            if($valid['Tmax']){
            if($valid['Tmin']){
            if($valid['H']){
            if($valid['P']){
            if($valid['W']){
            if($valid['G']){
            if($valid['B']){
            if($valid['R']){
            if($valid['RR']){
            if($valid['S']){
            if($valid['D']){
            if($valid['A']){
            // extra sensors
            if(isset($extraQueryParams) && is_array($extraQueryParams)){
        $apiLog['info'][] = "Not yet time to update the db, saving new data to cache/apiCache.txt";
    $apiLog['info'][] = "Generating log file cache/apiLog.txt";
    $updateLog = "";
    file_put_contents($base."cache/apiLog.txt",$updateLog);
    if($convertUgp){
        file_put_contents($base."cache/apiLogConvertUgp.txt",$updateLog);
    // return success status to caller
    echo "Success";
    // Functions
    // Dew point calculation
    // accepts temperature [C] and humidity [%]
    // returns dew point [C]
    function dewpoint($dewT,$dewH){
        $calcD = round(((pow(($dewH/100), 0.125))*(112+0.9*$dewT)+(0.1*$dewT)-112),1);
        return $calcD;
    // Apparent temperature calculation
    // accepts temperature [C], humidity [%], wind speed [m/s]
    // returns apparent temperature [C]
    function apparent($apparentT,$apparentH,$apparentW){
        $e = ($apparentH/100)*6.105*pow(2.71828, ((17.27*$apparentT)/(237.7+$apparentT)));
        $calcA = round(($apparentT + 0.33*$e-0.7*$apparentW-4),1);
        return $calcA;
    // Average wind bearing
    // accepts wind directions as an array and data as number between 0 and 360
    function avgWindUpdate($directions) { // based on http://en.wikipedia.org/wiki/Yamartino_method
        $sinSum = 0;
        $cosSum = 0;
        foreach ($directions as $value) {
            $sinSum += sin(deg2rad($value));
            $cosSum += cos(deg2rad($value));
        return ((rad2deg(atan2($sinSum, $cosSum)) + 360) % 360);
    function generateAPILog(){
        global $apiLog;
        global $base;
        // create log and exit update script
        $updateLog = "";
Post by alexvanuxem » Thu Aug 24, 2023 6:40 pm
do have a file ?
had some outages due to updating, imported data but its not saved in database
cheers
a
milesb
Post by milesb » Thu Aug 24, 2023 10:14 pm
The last api.php I received from Jachym resolved the database update issue.
Post by alexvanuxem » Fri Aug 25, 2023 8:37 am
to be clear, the api.php that Jachym shared only in code here a few posts above?
Post by FSC830 » Fri Aug 25, 2023 1:38 pm
Just click to "Code: Select all" (see headline of code block) and paste the clipboard afterwards to a new file api.php, then you will got it. :)
spd2612
Software: Meteobridge Pro 2
Post by spd2612 » Fri Aug 25, 2023 2:37 pm
Is there any updates in that Api file ?
Mine is working fine now updates are thru the ecowitt plugin with the original API from Cranberry
I have had them get corrupt before
Davis Pro 2
Meteobridge Pro2
GW 2000
WH57 Lightning Detector
milesb
Post by milesb » Fri Aug 25, 2023 3:55 pm
alexvanuxem wrote: Fri Aug 25, 2023 8:37 am to be clear, the api.php that Jachym shared only in code here a few posts above?
I received the file directly from Jachym, but it is the same as the one he posted in this thread. (I compared the two files with Notepad++)
xl1954
Station model: Ecowitt
Software: API Meteotemplate
Post by xl1954 » Sun Aug 27, 2023 7:15 am
Hello
After Update with the new api.php all is allright
For api Netatmo, Weewx run again correctly
For me php8.1 or 8.2 is runing correctly
Have a nice day
steph
Post by steph » Fri Sep 01, 2023 5:34 am
Hello everyone,
I had installed version 19.0 without any problems but I noticed that the interactive banner no longer worked.
So I reinstalled the files
createConfig.php
setup.php
header.php
the banner works again but it made me go back to Template 18.0.
I upgraded to Template 19.0 but the banner no longer works.
A solution ?
THANKS
amonphi
Station model: Ecowitt GW1003
Post by amonphi » Fri Sep 01, 2023 6:56 am
Hello Everyone,
I confirm that I also installed the 19.0 version, enabled first PHP8.2 In Altervista without errors, slowly I see how it behaves because some Bolcks do not load anymore but, if I remember correctly some of them were an updated version of @davidefa and maybe I will have to restore them.
More than anything else, someone can tell me if now I owe or not also update MySQL from version 5.6 to version 8 in Altervista? I am not very experienced and I would not like to do damage especially at the database.
MySQL Altervista.jpg (39.51 KiB) Viewed 76039 times
Thanks in advance
justinhow
Location: Dumfries, Scotland, UK. My site is geo restricted
Post by justinhow » Fri Sep 01, 2023 5:51 pm
Hi all,
I have just done the upgrade from 18 to 19 and PHP 7.x to PHP 8.2.10.
As far as I can see after a quick look most of the site is still working OK, EXCEPT the Steelseries Gauges plugin (4.0) is no longer working (all showing 0/min). This still works on my site if I run under PHP 7 but not if I run under PHP 8.2.
Any ideas?
Justin
PS Thanks Jachym - great work!
Station: Davis Vantage Pro2, Weather Display, meteotemplate 19.0
My Weather website: https://www.dumfries-weather.com (this site is geo-restricted)
Latest VERiFIED meteotemplate users.txt file is Here
Sydpub
Post by Sydpub » Fri Sep 01, 2023 10:01 pm
Same here: no ssGauges or RSS feeds at php 8.x. Fine at php 7.2. I presume these issues will be looked at when the blocks and plugins are addressed. In the meantime I'll remain at 7.2. I'm very pleased that Meteotemplate is receiving attention... thank you Jachym!
weather.sydenham.com
justinhow wrote: Fri Sep 01, 2023 5:51 pm Hi all,
I have just done the upgrade from 18 to 19 and PHP 7.x to PHP 8.23.
Any ideas?
Justin
tobydude
Software: Weatherdiaplay
Post by tobydude » Sat Sep 02, 2023 7:55 am
This php upgrade version does not work for me.
But I can very well live without it.
But worse is the fact that netatmo doesnt kommunicate with the weater program. (Weather Display)
What is the point of having a weaterstation if it doesnt registrate temperature and wind on a weatherpage?
I em considering buing a new weather station that acctually work.
Also I think that the webcam (block and plugin) should be updateted bacause the webcam doesnt work either.
amonphi
Post by amonphi » Sat Sep 02, 2023 5:17 pm
Instead I,
it will certainly be my ignorance on the subject but, I continue not to understand why if I have activated PHP8.2 in the Altervista, in Meteothemplate I still tell me that "You Are Using Php Version 7.3.33". I updated it 2 days ago but, still nothing.
I feel frustrated!
Having said that, after updating to the Version 19.0 I have slowdowns in opening the template and loading the following blocks:
forecastGraphical
outlook
meteogram (I have V4.0, ok to version 3.6)
lightning
currentMap
rain (I have the V7.2, sometimes it loads it sometimes not, and I have to force it manually)
I hope someone knows how to help me
milesb
Post by milesb » Sat Sep 02, 2023 6:31 pm
FSC830 wrote: Thu Aug 24, 2023 10:56 am Hi Jachym,
The database not updating has returned for me. The new api file initially fixed the problem, but the database stopped updating on 9/1/23 at 3AM. The Current block is still updating as normal.
justinhow
Post by justinhow » Sat Sep 02, 2023 6:36 pm
I have back revved the PHP to 7.4 as I was finding that my meteotemplate site was showing offline too much. The realtime current bloc/dials were still showing current readings though.
FYI - I use the meteotemplate API (from Weather Display)
milesb
Post by milesb » Sat Sep 02, 2023 6:42 pm
My site has always shown "Online" after update to 19.0, the only issue I've encountered is the database updates.
DadOfZelda
Software: Meteohub
Post by DadOfZelda » Wed Sep 06, 2023 6:27 am
A short report after doing an upgrade to v19
The update went on with no problem, only green checkmarks.
The site seems to work normaly on php 7.4.
I changed to php 8, and as some others says i did not get any updates. and also some blocks stop working.
I got http error 500 when running CRON for the updates file. (I use the meteohub process)
When change back to php 7.4 on webserver updates work again, but still some block not working as ssGauges
UPDATES!
After a day or two my block ssGauges start to show information again. But still on php 7.4
Kind Regards
Christian
justinhow
Post by justinhow » Wed Sep 06, 2023 11:09 am
Lets hope we get an update from Jachym about these reported issues soon.
spd2612
Post by spd2612 » Wed Sep 06, 2023 11:58 am
Im on php 8.1.26 and my update to 19 has not had any issues except for current block which is expected alot of blocks and plugins are old and out of date
Benn running fine since it was released
Davis Pro 2
Meteobridge Pro2
GW 2000
