Headings in blocks.
tobydude
Software: Weatherdiaplay
Headings in blocks.
Post by tobydude » Tue Jan 30, 2018 7:10 pm
Hi.
In some blocks I can make my own headings.
But in some blocks, making headings is not possible. (I think).
Is it possible to make an option for the users to make headings in future blocks?
Example: Image
Example: Image
http://fjærvollan.no/template/indexDesktop.php
Re: Headings in blocks.
Post by Dehatter » Wed Jan 31, 2018 7:15 pm
When I want a heading, I use the menuBlock option. Not ideal as you get the three lines in the left corner, but you do get a heading.
tobydude
Post by tobydude » Wed Jan 31, 2018 7:44 pm
Thanks for answer.
Not sure what you mean?
On your own website, how will you make a heding as this?
Post by Dehatter » Wed Jan 31, 2018 7:52 pm
Your can go see how it looks, but I also attached some pics.
Post by Jachym » Wed Jan 31, 2018 8:37 pm
in general the aim is to make blocks as compact as possible because the homepage has many of them. I only included headings for ones which could be unclear. Each block has its separate code, so it is not possible to just add some code in some general file and have heading in all blocks. I would have to update all of them because the heading would have to be added separately to each. And I believe that those who dont have it are clear to everyone. If you think not, then of course feel free to add a heading, but you would need to do it directly in the block HTML.
tobydude
Post by tobydude » Wed Jan 31, 2018 10:23 pm
Dehatter wrote: Wed Jan 31, 2018 7:52 pm Your can go see how it looks, but I also attached some pics.
Thanks.
I got it. :)
tobydude
Post by tobydude » Wed Jan 31, 2018 10:25 pm
Jachym wrote: Wed Jan 31, 2018 8:37 pm If you think not, then of course feel free to add a heading, but you would need to do it directly in the block HTML.
Thanks. Understand.
Post by Jachym » Thu Feb 01, 2018 5:02 am
If you want to make it consistent with the rest, use the H2 tag:
<h2>Title</h2>
tobydude
Post by tobydude » Thu Feb 01, 2018 10:55 am
Jachym wrote: Thu Feb 01, 2018 5:02 am If you want to make it consistent with the rest, use the H2 tag:
<h2>Title</h2>
Thanks. I will.
But where do I put the H2 tag?
<h2>Title</h2>
Post by Jachym » Thu Feb 01, 2018 10:57 am
at the top of the block HTML, or wherever you want the title to be
tobydude
Post by tobydude » Thu Feb 01, 2018 12:32 pm
Ok, thanks.
