Sorry to be dim here but.........
Chat about anything... (as long as it is a sensible debate :-) )
Brandon Barometer
Post by Brandon Barometer » Thu Aug 31, 2017 6:10 am
I know it’s me being dumb but how do you put a sticker on your forum signature. I must be doing it wrong :|
iatros
Re: Sorry to be dim here but.........
Post by iatros » Thu Aug 31, 2017 6:37 am
Hi Brandon
go to your profile -> edit -> signature
In the field you have to use img html tag to insert the sticker as an image:
best regards, Martin
Language Admin für Deutsch
Brandon Barometer
Post by Brandon Barometer » Fri Sep 01, 2017 6:31 pm
Martin,
Many thanks, as you can see it now works!
Beny
Station model: Davas Vantage pro 2
Post by Beny » Mon Aug 06, 2018 7:01 pm
Hello boys
I have the same problem, please how did you finally solve it?
See: http://pocasinakladne.cz/template/plugi ... s/maxT.php
Post by Johnny » Tue Aug 07, 2018 8:38 am
Hi Beny,
Martin does show the answer above. You need to go click on your name top right, then click on 'Profile', then click on 'Edit Profile', then on the left click 'Edit Signature' Then you need to paste your signature code into the text box. (see image below).
I am assuming that you have installed the stickers plugin before any of the above.
