Gauges limit
Posted: Fri Mar 02, 2018 9:31 pm
by giordolo
Hi, I have setted the rain Gauges limit at 50 but it seems not working, the rain gauges is at 160
Re: Gauges limit
Posted: Sat Mar 03, 2018 8:46 am
by Johnny
Hi Giordolo, try setting the rain range limit within the Live Gauges API setup (the plugin setup). See the bottom item in the image below.
administration/plugins setup/liveGaugesAPI
Live Gauges.JPG (65.27 KiB) Viewed 6984 times
Re: Gauges limit
Posted: Sat Mar 03, 2018 10:22 am
by giordolo
Thanks, I mean that this implicate to have a tab dedicated to gauges. True?
Re: Gauges limit
Posted: Sat Mar 03, 2018 12:45 pm
by chrisecurtis
Gauges are a plugin as well as a block. You can put it wherever you like in the menu.
Re: Gauges limit
Posted: Sat Mar 03, 2018 3:55 pm
by giordolo
mmm something went wrong
Anyway I have not added the gauges in the menu but the attachments are related to the plugin config page and the rain gauge in the home page block
Re: Gauges limit
Posted: Sun Mar 04, 2018 3:45 am
by Dehatter
He is using the steel series. The limits are in the plugin setup as well though, not the main template set up.
Goto plugin setup. Select SteelSeries. Down the set up just a bit your will find the following:
Here is where you adjust the limits for all the SteelSeries guages. You can make aesthetic changes to the gauges as well.
Good Luck!
Re: Gauges limit
Posted: Thu Mar 08, 2018 9:51 pm
by giordolo
Oh yeah! Great! It works very well!
Lot of thanks to you! gimme five!
Giordolo
