Gauges limit
giordolo
- Station model: WH3081
Gauges limit
Hi, I have setted the rain Gauges limit at 50 but it seems not working, the rain gauges is at 160
- 2.JPG (17.2 KiB) Viewed 6999 times
- 1.JPG (37.52 KiB) Viewed 6999 times
- Johnny
- Developer
Re: Gauges limit
Hi Giordolo, try setting the rain range limit within the Live Gauges API setup (the plugin setup). See the bottom item in the image below.
administration/plugins setup/liveGaugesAPI
giordolo
Re: Gauges limit
Thanks, I mean that this implicate to have a tab dedicated to gauges. True?
chrisecurtis
Re: Gauges limit
Gauges are a plugin as well as a block. You can put it wherever you like in the menu.
giordolo
Re: Gauges limit
mmm something went wrong
Anyway I have not added the gauges in the menu but the attachments are related to the plugin config page and the rain gauge in the home page block
- 2.JPG (10 KiB) Viewed 6969 times
- 1.JPG (30.2 KiB) Viewed 6969 times
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
Re: Gauges limit
He is using the steel series. The limits are in the plugin setup as well though, not the main template set up.
Goto plugin setup. Select SteelSeries. Down the set up just a bit your will find the following:
Here is where you adjust the limits for all the SteelSeries guages. You can make aesthetic changes to the gauges as well.
Good Luck!
Good Luck!
giordolo
Re: Gauges limit
Oh yeah! Great! It works very well!
Lot of thanks to you! gimme five!
Giordolo
Giordolo
