Gauges limit
giordolo
Station model: WH3081
Gauges limit
Post by giordolo » Fri Mar 02, 2018 9:31 pm
Hi, I have setted the rain Gauges limit at 50 but it seems not working, the rain gauges is at 160
Re: Gauges limit
Post by Johnny » Sat Mar 03, 2018 8:46 am
Hi Giordolo, try setting the rain range limit within the Live Gauges API setup (the plugin setup). See the bottom item in the image below.
administration/plugins setup/liveGaugesAPI
Live Gauges.JPG (65.27 KiB) Viewed 6979 times
giordolo
Re: Gauges limit
Post by giordolo » Sat Mar 03, 2018 10:22 am
Thanks, I mean that this implicate to have a tab dedicated to gauges. True?
chrisecurtis
Re: Gauges limit
Post by chrisecurtis » Sat Mar 03, 2018 12:45 pm
Gauges are a plugin as well as a block. You can put it wherever you like in the menu.
giordolo
Re: Gauges limit
Post by giordolo » Sat Mar 03, 2018 3:55 pm
mmm something went wrong
Anyway I have not added the gauges in the menu but the attachments are related to the plugin config page and the rain gauge in the home page block
Re: Gauges limit
Post by Dehatter » Sun Mar 04, 2018 3:45 am
He is using the steel series. The limits are in the plugin setup as well though, not the main template set up.
Goto plugin setup. Select SteelSeries. Down the set up just a bit your will find the following:
Here is where you adjust the limits for all the SteelSeries guages. You can make aesthetic changes to the gauges as well.
Good Luck!
giordolo
Re: Gauges limit
Post by giordolo » Thu Mar 08, 2018 9:51 pm
Oh yeah! Great! It works very well!
Lot of thanks to you! gimme five!
Giordolo
