GraphCombined Issue
Ken Good
GraphCombined Issue
Post by Ken Good » Fri Mar 09, 2018 1:33 pm
I am in the process of setting up another weather website for a family member (in addition to the site I have for myself). I have set up a second sql server on my ISP. The installation has gone well with the exception that this block is now blank. It worked originally, but now is just blank. It still works on my website. Any thoughts?
You can see the page at: http://jamiesbluffdaleweather.com/templ ... esktop.php
I have left the block up even though it is blank to see if any of you geniuses can tell me where I have messed up.
My page where it is working on the same ISP is at: http://bullardweather.com/template/indexDesktop.php
Thanks in advance.
Ken
Ken Good
Re: GraphCombined Issue
Post by Ken Good » Fri Mar 09, 2018 1:35 pm
I will add that this new site will not list the blocks that are available to install and I have to go to meteotemplate.com and install them the old way. I am wondering if it is just a set up issue and whether I should just delete and start over to clear whatever is causing the communication error.
Post by Jachym » Fri Mar 09, 2018 2:20 pm
the problem is in the apostrophe in the title of your page, insert a backslash in front of it (\') or use the HTML code for it
Ken Good
Post by Ken Good » Fri Mar 09, 2018 10:52 pm
Thanks to the "moon and back."
My version of a Texas expression.
Ken
Ken Good
Post by Ken Good » Fri Mar 09, 2018 10:56 pm
Fixed. You make it look so easy.
