Stickers - Interactive works - others dont
JHoke
Software: weeWX
Post by JHoke » Mon Apr 16, 2018 10:17 am
I am running the current version of Meteotemplate and Stickers plugin, and interactive banners work perfectly, but the 'static' stickers are not showing any text, just icons
Here are some of the examples from the sticker plugin config/info page
And as you can see in my sig below the interactive stickers (both static and animated) is just fine
Server Info:
  • Ubuntu 16.04 (Hosted on Amazon Lightsail)
  • Apache Server version: Apache/2.4.18 (Ubuntu) Server built: 2017-09-18T15:09:02
  • php Version: 7.0.28-0ubuntu0.16.04.1 (Latest version in Ubuntu Canonical)
When I try to access those stickers above with errors=1 set, I get the following in my apache error log for this virtualhost:
[Mon Apr 16 05:59:45.932945 2018] [:error] [pid 25532] [client 75.97.234.87:53906] PHP Warning:  imagettfbbox(): Could not find/open font in /var/www/weather/public_html/plugins/stickers/sticker800_170.php on line 289
[Mon Apr 16 05:59:45.932959 2018] [:error] [pid 25532] [client 75.97.234.87:53906] PHP Warning:  imagettftext(): Could not find/open font in /var/www/weather/public_html/plugins/stickers/sticker800_170.php on line 292
I do see the font called on those lines, with proper permissions, in /plugins/stickers/fonts
GD Support is enabled for FreeType (from phpinfo();)
  • GD Support enabled
  • GD headers Version 2.1.1
  • GD library Version 2.1.1
  • FreeType Support enabled
  • FreeType Linkage with freetype
  • FreeType Version 2.6.1
Is this a limitation of the PHP Version, something else?
EDIT:
Ok, I just did the following:
Copied sticker800_170.php to stickerTest.php
Changed lines 289 & 292 to prefix the font name with the 'fonts/' directory so that it now looks like:
        function textCenter($img, $x, $y, $text, $size, $ttfsize, $color, $angle) {
                $gsSupport = gd_info();
                if ($gsSupport["FreeType Support"] == 0){
                   $x -= (imagefontwidth($size) * strlen($text)) / 2;
                   $y -= (imagefontheight($size)) / 2;
                   imagestring($img, $size, $x, $y - 3, $text, $color);
                else {
                        $box = imagettfbbox ($ttfsize, $angle, 'fonts/Roboto-Bold.ttf', $text);
                        $x -= ($box[2] - $box[0]) / 2;
                        $y -= ($box[3] - $box[1]) / 2;
                        imagettftext ($img, $ttfsize, $angle, $x, $y, $color, 'fonts/Roboto-Bold.ttf', $text);
And it works ....
Not sure why this was needed on this install, but it seems to be working for other people out of the box ...
Jachym - if you have any thoughts/ideas I'm all ears and if you need any other info just let me know.
Station: Davis Vantage Pro 2
Software: weeWX
Hardware: Raspberry Pi 3
WebSite: https://nepaweather.com/
Re: Stickers - Interactive works - others dont
Post by Jachym » Mon Apr 16, 2018 11:27 am
Strange, but some servers behave very oddly. It works for me in the original state as well
JHoke
Software: weeWX
Post by JHoke » Mon Apr 16, 2018 5:40 pm
Yeah ... but if you have the proper path to the fonts does it break others? If not, would it be feasible to fix in next release?
Otherwise I'll just keep some notes that I need to edit in future updates as it is not pathing properly
The main difference I see between the interactive and non-interactive versions is that in the interactive scripts you set a variable $fontFace as follows
	$fontFace = "fonts/".$_GET['font'].".ttf";
Then you call it in the script as
imagettftext ($img, $ttfsize, $angle, $x, $y, $color, $fontFace, $text);
But in the non-interactive scripts you just place
imagettftext ($img, $ttfsize, $angle, $x, $y, $color, 'Roboto-Bold.ttf', $text);
Which is missing the path to the ttf file "fonts/" ... I fixed this by simply changing the calls to Roboto-Bold.ttf to fonts/Roboto-Bold.ttf ... but I wonder if $fontFace being set to that would not be better ... will need to test
Also, found an issue with the 800x150 script - its missing mph as a windspeed
 if($displayWindUnits=="kmh"){
                $windUnits = "km/h";
        if($displayWindUnits=="ms"){
                $windUnits = "m/s";
so until I added
        if($displayWindUnits=="mph"){
                $windUnits = "mph";
It would not put the 'mph' units under the windspeed
Software: weeWX
Post by andyk1 » Tue Apr 24, 2018 10:26 pm
Sorry if this post is a week late and a dollar short but I ran across a similar problem in another part of my site changing from one host to another.
My problem started when all worked fine at original host with massive problems and thanks to the help and suggestions of many offering different clues as to what my problem was. I'm by no means a php expert. Anyway changing hosts totally ruined my working copy. The way I ended up getting it solved and again with the suggestion of one person from this site my php version was lowered till it finally worked. I wasn't to thrilled going from ver 7 something but am stuck at php ver 5.7 and without checking my host am fairly certain that is what I am using. All for the most part seems to work fine on my site and reading through these post I see it working for some out of the box and not for others. As I said... not wanting to open a can of worms but it's a though.
This line of code reminded me of my problem and was fairly similar to mine. The pid xxxxx and PHP Warning is what reminded me.
Just a suggestion to think about.
