Database update Interval - API
Posted: Fri Apr 20, 2018 11:50 am
by WSKO_Karlchen
how can i change the update Interval of the integrated mySQL from 5 minutes to 1 minute or less?
Thank you ;)
Re: Database update Interval - API
Posted: Fri Apr 20, 2018 2:43 pm
by tpweather
If WD its in the Meteotemplate setup in Control Panel.
Posted: Fri Apr 20, 2018 10:25 pm
You can change the update interval of the blocks such as Current Conditions (this is eg. the interval in WD). You cannot change the db interval, that is fixed to 5 minutes. This is handled by the api.php. So if you set your updates more frequently (for example 10s) you will see updates every 10s in some blocks and those values will be cached and then saved as one dataset every 5 minutes.
