Database update Interval - API
WSKO_Karlchen
Station model: Davis Pro 2 aktiv
Software: weewx 4.1.1
Post by WSKO_Karlchen » Fri Apr 20, 2018 11:50 am
how can i change the update Interval of the integrated mySQL from 5 minutes to 1 minute or less?
Thank you ;)
Wetterservice Koblenz
tpweather
Re: Database update Interval - API
Post by tpweather » Fri Apr 20, 2018 2:43 pm
If WD its in the Meteotemplate setup in Control Panel.
Post by Jachym » Fri Apr 20, 2018 10:25 pm
You can change the update interval of the blocks such as Current Conditions (this is eg. the interval in WD). You cannot change the db interval, that is fixed to 5 minutes. This is handled by the api.php. So if you set your updates more frequently (for example 10s) you will see updates every 10s in some blocks and those values will be cached and then saved as one dataset every 5 minutes.
