Post
by Jachym » Fri Apr 20, 2018 10:25 pm
You can change the update interval of the blocks such as Current Conditions (this is eg. the interval in WD). You cannot change the db interval, that is fixed to 5 minutes. This is handled by the api.php. So if you set your updates more frequently (for example 10s) you will see updates every 10s in some blocks and those values will be cached and then saved as one dataset every 5 minutes.
