I would like to use the GrLevelX (version 2.0) block, however I cannot get it to work with the radar site located here in Tucson. I contacted the local US Weather Service office just to make sure I am using the proper radar code. They told me it is KEMX. I plugged that code (as lower case) into the "Four-letter abbreviation of the radar site" field as directed in the block setup script. I did not modify any other field. I have yet to see anything in the block.
Any suggestions?
Can't get GrLevelX to work
- aznetcowboy
Tom Wills
nineback
- Station model: Davis Pro2
- Software: WeeWX
Re: Can't get GrLevelX to work
GRLevelX requires a stand-alone program running on your PC that uploads images to your server. Meteotemplate then uses these images in the GRLEVELX block. The block does not use the NWS site.
