How do I remove menu from block
aznetcowboy
Post by aznetcowboy » Thu Apr 26, 2018 9:19 pm
Just wondering why so many blocks have a "Menu" is the upper left-hand corner which when clicked on only display the block name? Is there a way to not display these "Menus"?
Tom Wills
John B
Re: How do I remove menu from block
Post by John B » Fri Apr 27, 2018 12:22 am
Normally, cowboy, you have to put in the menu (menuBlock) bars yourself when setting up your home page.
As per below, wherein is one block with a menu bar and which contains blocks warningsAU, currentAustralia and partnerStations. Ignore the HTML and text, they are just my own additions.
dynamicText
text
interactiveGraph
summary
menuBlock(<font size="2.5"><b><u>'click' the menu bars for options</u></b></font>,warningsAU;currentAustralia;partnerStations)
stationStatus
I hope this helps.
Post by Dehatter » Fri Apr 27, 2018 7:23 pm
aznetcowboy wrote: Thu Apr 26, 2018 9:19 pm Just wondering why so many blocks have a "Menu" is the upper left-hand corner
If you are only using 1 block in a space (as most of yours are) you do not need to enter the block into a menu block format.
menu blocks are generally only used for multiple blocks in the same space.
example here:
this is the center column on my site. the 3 lines list the blocks that are included in the menu block. on your site, you only have 1 block in your menu block so that is what it lists.
tom
