Database identical T, Tmax, Tmin. (NetAtmo)
audun
Station model: NetAtmo
Software: API
Post by audun » Mon May 14, 2018 9:49 pm
Hello everybody, this is my first post here :)
I've noticed identical values being stored to DB for T, Tmax, Tmin. Using API for NetAtmo.
It doesn't affect stats (that I have noticed), just makes me wonder why the colums are needed in the first place?
[EDIT] : Forgot to mention it's like this for imported data aswell.
Image(yes it was a nice day today)
Any comforting explanations out there? Otherwise I'll loose my sleep over this, thinking something is VERY wrong :lol:
regards
Audun
http://vindkast.no
Re: Database identical T, Tmax, Tmin. (NetAtmo)
Post by andyk1 » Mon May 14, 2018 11:05 pm
audun wrote: Mon May 14, 2018 9:49 pm Hello everybody, this is my first post here :)
regards
Audun
http://vindkast.no
The T,Tmax,Tmin are calculated at 5 min intervals. If there is no change in temp, hum, barometer then all would be equal. Try when you know temp, hum, baro etc changes and you will then see the changes.
audun
Software: API
Post by audun » Mon May 14, 2018 11:20 pm
Thanks for your soothing reply. I can sleep now :)
Everything is cool then, since my DB updates at 5 min intervals with the API, it will always be like this :)
My old data was also stored with the same frequency (5min).
audun
Post by andyk1 » Tue May 15, 2018 4:58 am
Yes looking at your chart again I see you had very little changes in temp for up to 15 min and with only a 0.1 change in 5 min. Am sure if you had a few deg. change in that 5 min period you would see the changes. And yes it does look like you had a nice day there. :D
