Rain Block YTD needs amount updated
- aznetcowboy
As I have not been using Meteotemplate since the beginning of 2018 nor have I been using the Rain Block since the beginning of 2018 (started in June), it shows only 2.38" instead of the actual 5.19" of rain YTD (we had a very wet February). Is there a way to force the update of the YTD amount to 5.19"?
Tom Wills
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
Re: Rain Block YTD needs amount updated
Depending on how precise you want to get, you can edit the data and lump the rest in as all in one day, or can actually edit the data for each rain event until you catch up.
(Control Panel, Database, Edit Data)
At least that is what I did.
