Up to a few months ago i was running both Meteotemplate and the Saratoga script on my server with no issues.
Problems starting with pages hanging and pages on both scripts taking ages to load.
After weeks of trouble shooting which involved moving all my data to a new server the problem persisted.
To cut a long story short the only way i could get the Saratoga script to work was to delete the Meteotemplate Template folder from my server.
This method worked across three different servers i had my websites hosted on.
I thought space may have been an issue but both scripts are relatively small so very unlikely a reason for the problems. Also both scripts ran with no issues for a few years so why problems now out of nowhere.
So just wondering have others who use both scripts have had issues with running both on the same server??
Problems running Saratoga and Meteotemplate scripts
mikewaterford
- Software: weather Display
Re: Problems running Saratoga and Meteotemplate scripts
Im 100% sure the problem is with one of them, but not with the fact you have both, server log should show some errors if pages dont load
nineback
- Station model: Davis Pro2
- Software: WeeWX
I'm running both with no problems.
mikewaterford
So was i up to a month ago. I changed nothing at my end and the server wasn't touched either so its a strange one.
I will try again and load Meteotemplate and check the server logs for errors.
One good thing did come out of this, i finally set up my own server as a back up and its running Saratoga script with no errors.
