Meteohub plugin
Posted: Tue Oct 30, 2018 10:53 pm
by Mauro
Hello everyone!
There seems to be a problem with the "current conditions" block and the "meteohub" plugin used to feed the weather data.
The value of solar radiation is significantly lower than that found in the clientraw.txt file.
Has anyone had the same problem?
Thanks to all!
Mauro
Re: Meteohub plugin
Posted: Sat Nov 03, 2018 10:26 pm
by Mauro
Hello Jachym!
Any suggestions?
Thanks!
Meteohub plugin ***SOLVED***
Posted: Tue Nov 06, 2018 9:50 am
by Mauro
Hello everyone!
I think I have solved the problem of incorrect solar radiation reading.
The value of field 34 in the clientraw.txt file (solar reading) is read from the update.php file of the Meteohub plugin.
The correct value should instead be read from field 127 (VP Solarwm).
So it's enough to change the value of the array from 34 to 127 in the update.php file.
    if($rawData[127]!="-"){
        $rawUpdate['S'] = $rawData[127];
Re: Meteohub plugin
Posted: Tue Nov 13, 2018 6:33 pm
it looks like it depends on which station model you use, because for most people the other field number works fine, glad you fixed it
Re: Meteohub plugin
Posted: Tue Nov 13, 2018 8:03 pm
by Mauro
Thanks Jachym!
Hope it can help.
Mauro
Re: Meteohub plugin
Posted: Tue Nov 27, 2018 12:05 am
by andyk1
I know a little late but for Ambient ObserverIP and meteobridge it is 126.7
Re: Meteohub plugin
Posted: Sun Dec 16, 2018 5:59 pm
by PNCATTE
MERCI pour ce correctif
Cordialement
Re: Meteohub plugin
Posted: Sun Dec 16, 2018 9:00 pm
by Mauro
Je suis content d'avoir été utile :)
Bonne soirée!
