Hello everyone!
There seems to be a problem with the "current conditions" block and the "meteohub" plugin used to feed the weather data.
The value of solar radiation is significantly lower than that found in the clientraw.txt file.
Has anyone had the same problem?
Thanks to all!
Mauro
Meteohub plugin
- Mauro
- Software: Meteohub
Re: Meteohub plugin
Hello Jachym!
Any suggestions?
Thanks!
Any suggestions?
Thanks!
- Mauro
Meteohub plugin ***SOLVED***
Hello everyone!
I think I have solved the problem of incorrect solar radiation reading.
The value of field 34 in the clientraw.txt file (solar reading) is read from the update.php file of the Meteohub plugin.
The correct value should instead be read from field 127 (VP Solarwm).
So it's enough to change the value of the array from 34 to 127 in the update.php file.
if($rawData[127]!="-"){
$rawUpdate['S'] = $rawData[127];
- field127.png (5.23 KiB) Viewed 8728 times
- field34.png (6.32 KiB) Viewed 8728 times
Re: Meteohub plugin
it looks like it depends on which station model you use, because for most people the other field number works fine, glad you fixed it
- Mauro
Re: Meteohub plugin
Thanks Jachym!
Hope it can help.
Mauro
Hope it can help.
Mauro
PNCATTE
- Software: WLIP
Re: Meteohub plugin
MERCI pour ce correctif
Cordialement
Cordialement
- Mauro
Re: Meteohub plugin
Je suis content d'avoir été utile
Bonne soirée!
Bonne soirée!
