Meteohub plugin
Mauro
Software: Meteohub
Meteohub plugin
Post by Mauro » Tue Oct 30, 2018 10:53 pm
Hello everyone!
There seems to be a problem with the "current conditions" block and the "meteohub" plugin used to feed the weather data.
The value of solar radiation is significantly lower than that found in the clientraw.txt file.
Has anyone had the same problem?
Thanks to all!
Mauro
Mauro
Software: Meteohub
Re: Meteohub plugin
Post by Mauro » Sat Nov 03, 2018 10:26 pm
Hello Jachym!
Any suggestions?
Thanks!
Mauro
Software: Meteohub
Meteohub plugin ***SOLVED***
Post by Mauro » Tue Nov 06, 2018 9:50 am
Hello everyone!
I think I have solved the problem of incorrect solar radiation reading.
The value of field 34 in the clientraw.txt file (solar reading) is read from the update.php file of the Meteohub plugin.
The correct value should instead be read from field 127 (VP Solarwm).
So it's enough to change the value of the array from 34 to 127 in the update.php file.
    if($rawData[127]!="-"){
        $rawUpdate['S'] = $rawData[127];
Re: Meteohub plugin
Post by Jachym » Tue Nov 13, 2018 6:33 pm
it looks like it depends on which station model you use, because for most people the other field number works fine, glad you fixed it
Mauro
Software: Meteohub
Re: Meteohub plugin
Post by Mauro » Tue Nov 13, 2018 8:03 pm
Thanks Jachym!
Hope it can help.
Mauro
Re: Meteohub plugin
Post by andyk1 » Tue Nov 27, 2018 12:05 am
I know a little late but for Ambient ObserverIP and meteobridge it is 126.7
PNCATTE
Software: WLIP
Re: Meteohub plugin
Post by PNCATTE » Sun Dec 16, 2018 5:59 pm
MERCI pour ce correctif
Cordialement
Mauro
Software: Meteohub
Re: Meteohub plugin
Post by Mauro » Sun Dec 16, 2018 9:00 pm
Je suis content d'avoir été utile :)
Bonne soirée!
