gfs map section
meteoparquecoimbra
- Station model: WMR928NX, Oregon Scientic
- Software: Virtual Weather Station
gfs map section
Hello, I noticed a few days ago that the map section of the GFS block stopped working, is there a problem?
Thaks
Thaks
- Mauro
- Software: Meteohub
Re: gfs map section
Same issue...
- dmgould
Re: gfs map section
Mine has been blank for several days as well. There is probably a change in the data source. I haven't yet gone into the code to see about that.
meteoparquecoimbra
Re: gfs map section
How is this theme? Does anyone know why this block does not work?
- Mauro
Re: gfs map section
Probably a data source change
- Mauro
Re: gfs map section
Any news?
Re: gfs map section
I dont see any problems
http://www.meteotemplate.com/template/i ... ?block=gfs
- Mauro
Re: gfs map section
Hello!
Same for me. The map doesn't work...
Mauro
Mauro
Re: gfs map section
Aha, I see, sorry I just looked at the graphs.
The problem is with the data source. The old links are dead and the new ones use dynamic numbering, ´which in fact makes it impossible to use further. Once you click the image, it requests the link from the server, but this link is dynamic. It uses logical naming, i.e. date and hour of forecast, but the problem here is that the images are updated at a certain time.
What I would need is some kind of an API, where you send a particular request and receive an exact link. HTML scraping is not really an option - this is something I used in the past and the result is that blocks/plugins stop working very often because a single change in the HTML makes it non-functional - even such small change as adding a space. The script has exact parts of the code it looks for and if it does not find them, it gives up.
Does anyone know any GFS API?
- Station model: Ecowitt WS90
Re: gfs map section
It's been more than a few days since it's stopped. I checked around and every station I looked at (about 10 roughly) quit. I'm trying to remember but it's been over 2 weeks or more. Checking Jachym's link it did work and again checking around it is not working for anyone including myself. I guessed they changed links or API. On my page it is under the Windy radar/NOAA/LIGHTENING...... Menu.
Merry Christmas and Happy New Year to all that celebrate or your respective holidays.
