I detect a little issue with accent mark in "o" in spanish page name. My $pageName is "MeteoAlmendralejo.es - Servicio Meteorológico de Almendralejo". In the menu, in Info tab the "ó" character is bad codified in UTF8.
Jachym, could you add this line for future release ??
FIX:
menu.php:226
change: $defaultSpecs['aboutPage'] = array("pages/other/aboutPage.php",$pageName,"mticon-logo");
by this: $defaultSpecs['aboutPage'] = array("pages/other/aboutPage.php",utf8_encode($pageName),"mticon-logo");
Thank you very much.
Character Enconding problem in PageName
agallardo1980
Re: Character Enconding problem in PageName
Second part... If I modify the menu via admin and save changes, the menu.php is rewrited and I lose this changes
Any suggestion?
Any suggestion?
Usually an easy fix is to use the HTML symbol, ie. something like
When you save changes to the menu, these changes should be saved in separate text files in admin/menu/
agallardo1980
Thank you very much Jachym. The simplest solutions always is better
I fix with this in config:
$pageName = 'MeteoAlmendralejo.es - Servicio Meteorológico de Almendralejo';
Now the sitemap XML work OK, before was empty
Thanks again.
Thanks again.
