I have a question regarding the order of symbols in CurrentConditions block. Is the order of the symbols from left to right In that block fixed anyhow? My problem is, that I cannot change the order. When I modify the order of the respective letters (i.e. T, A, W, ...) within the block settings, the order of symbols on the homepage doesn‘t change accordingly. Is that the normal behaviour or is there anything else I have to consider when I want to change the order of symbols?
Thanks, Jens
Problem with currentconditions block
- Asobig
- Software: Meteobridge (Red)
Re: Problem with currentconditions block
The order is fixed, in the setup you only list the values you want to show.
- iatros
- Language Admin
the order is a table in the currentBlock.php (line 337 ff). You can change it there....
Thanks for your help.
WSKO_Karlchen
- Station model: Davis Pro 2 aktiv
- Software: weewx 4.1.1
How to include the sensors for leaf temperature „LT1“ and „LT2“ in the current block?
We want to use it for temperature 5cm above ground and 50cm above ground... and also Name it that way.
Currently the sensor is visualized in the leaf temperature block.
Any idea how to change it?
Greetings
Bjoern
http://www.wetter-koblenz.com
Greetings
Bjoern
Wetterservice Koblenz
