WLIP AND THE DATABASE
HILARIO
Software: WLIP
Post by HILARIO » Sun Mar 03, 2019 3:33 pm
Since I use Meteotemplate I use the WLIP plugin to upload data to the template, the truth is that it has always worked well, after changing the version to Weatherlink 2.0 I made the corresponding change from the URL to the plugin and it worked perfectly for me. Since a few days ago I observe that the data load works well since it loads every 5-6 minutes approximately or in some case with less time, but I am observing through the "Station Status" Block that the load to the database is About 30 minutes or more ago, until now it had not happened to me. I'm going around and I can not understand what is due, I do not understand why, because if the load is made at 5 minutes, why the database is loaded at 30 minutes or more leaving the state in "offline"?
Has anyone had this or a similar problem?
When this happens, I am seeing that the maximum, minimum and average data are not correct because it takes too much time to load the data in the database ...
Can someone help me? Thanks in advance, regards Hilario
