Wind Gust - MB vs MT
Post by Dehatter » Fri Jun 14, 2019 7:21 pm
I am not sure what I have done differently because I do not recall this issue before, and I do not know what has changed, but Wind Gust on MT seems NOT to be registering the max value from Meteobridge any longer.
I am wondering if it is because Meteobridge has changed its data formatting and max gust is in a different field than it used to be. I believe that MT is reporting an average and not the max, because it is generally several mph lower than reported in the MB live data table and at a different time.
Re: Wind Gust - MB vs MT
Post by Jachym » Fri Jun 14, 2019 8:22 pm
it is strange, however Meteobridge supports Meteotemplate directly, so even if some field changes I would assume Boris implements any necessary changes to his script that sends data to MT and it is still sending "max gust", but this is a question for Boris rather than me.
mchd17
Post by mchd17 » Sat Jun 15, 2019 1:59 am
hey dehatter
i will respond here and not the other thread you replied to that i started with this problem.
the same issue i had was resolved by Boris. I was using weather link bypass through mb and it was missing a few max gusts during the course of a day. he sent out an update and it fixed my problem. been running great since then. you should go to the mb forums and post your issue. give it some time for him to respond, patience is key. hope you get it figured out.
Post by andyk1 » Sat Jun 15, 2019 2:29 pm
I read about this on Meteobridges site and they addressed this issue in a new update. Just reboot your MB and it should fix it.
Oops, I should have read all the posts first. mchd17 already said the same.
Post by Dehatter » Sat Jun 15, 2019 10:51 pm
I do try and keep my MB updated. I had the June 11 update when I wrote the post. I have just updated again to get today's version (4.0-2160). We will see....
Today is showing correctly.
Post by andyk1 » Sun Jun 16, 2019 1:25 am
Weird, the June 11th MB update fixed it for me. Boris said it was his fault in the versions before the 11th he messed it up. I think the June 3rd or just after is when I noticed.
It's mentioned in WXFORUM also. Not an MT error.
Post by Dehatter » Wed Jun 26, 2019 2:48 pm
Jachym wrote: Fri Jun 14, 2019 8:22 pm Hi,
I am forwarding this same info to Boris but just wanted to provide an example.
meterbridge Live Data.jpg (421.12 KiB) Viewed 8173 times
Annotation 2019-06-26 104059.jpg (104.63 KiB) Viewed 8173 times
As one can see, the data stored in the data base is NOT the max data sent by the Meteobridge device.
Post by andyk1 » Thu Jun 27, 2019 3:40 am
Yes I'm seeing my MB is not matching my MT for the same 5 minute period. It's only off by a few mph but still. I have noticed the last few MB releases had a few bugs that where for the most part fixed pretty quickly.
