View the NOAA.txt
Tigro11
Station model: davis 6152
Software: weatherLink - cumulus mx
View the NOAA.txt
Post by Tigro11 » Fri Nov 15, 2019 3:10 pm
Hello guys, I have the site that stores data since 2011, I wanted to migrate the whole site with meteotemplate, I have only one doubt regarding my monthly and annual noaa files where both comparisons and monthly and annual reports are made.
I ask if there is a plugin or a block where you can then view the noaa.
I am attaching the link of my php that manages the display of the noaa
http://carlinometeo.altervista.org/stat ... ensile.php
Thank you all
Valerio
Lespius
Station model: Davis VP2
Re: View the NOAA.txt
Post by Lespius » Fri Nov 15, 2019 7:56 pm
Are you looking for something like this ?
http://www.meteo-cugy.ch/template/plugi ... /index.php
Tigro11
Post by Tigro11 » Sun Nov 17, 2019 9:28 am
hello, this is not the case, what you use is a report without graphics and does not mark with a different color or a bold font the minimum and maximum temeteas of the day.
The part where you can make both monthly and annual comparisons is completely missing.
would there be a page or block that can be customized?
I could integrate the php I use, if someone wants the sources to be able to work on it, ask me.
Lespius
Post by Lespius » Sun Nov 17, 2019 11:14 am
I don't think there is such template. I know yours, I used to use Graphweather.
Even if it is a very good software and easier to modify/customize, I think Meteotemplate is a more powerful tool, and visually more "modern".
Tigro11
Post by Tigro11 » Sun Nov 17, 2019 3:46 pm
I understand, it would be enough for me to be able to open my php page on meteotemplate, always staying within meteotemplate. It would already be a nice goal.
I tried to create a custom page, but I can't get php to load
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Sun Nov 17, 2019 7:10 pm
Hello Tigro11,
you can create a page like the attached link of Grapweather.
friendships
http://meteo-lignerolles.fr/custom/cust ... isons NOAA
Tigro11
Post by Tigro11 » Mon Nov 18, 2019 9:45 pm
José Luis perfect, just what I was looking for.
How can I integrate it into the meteotemplate?
Good nice job
Valerio
Jolumarali
Software: WlIP
Post by Jolumarali » Tue Nov 19, 2019 9:08 am
Ciao Valerio
devi creare una pagina personalizzata
sotto lo script
quindi nel tuo menu crea un link a questo
buona giornata.
josé luis
con traduttore
<!DOCTYPE html>
<html>
<head>
<h1>Confronto NOAA</h1>
</head>
<body>
<center><object type="text/html" data="http://carlinometeo.altervista.org/stat ... ensile.php" width="100%" height="3350">
</object>
</body>
</html>
Tigro11
Post by Tigro11 » Tue Nov 19, 2019 10:09 am
Ciao Luis,
ho fatto come dici,ma credo che la mia versione di php è vecchia,la tua versione sicuramente è più nuova.
http://carlinometeo2.altervista.org/tem ... ?page=NOAA
come vedi ho i caratteri sbagliati da quando ho installato la versione per meteotemplate
Sai dove posso scaricare la nuova versione di php per i confronti?
Grazie
Valerio
Jolumarali
Software: WlIP
Post by Jolumarali » Tue Nov 19, 2019 11:18 am
Valerio, se la mia versione è adatta a te posso inviarla, ho visto che nelle impostazioni la versione può essere in italiano.
solo per apportare alcune modifiche personali nel file constants.inc.php
buona giornata
Tigro11
Post by Tigro11 » Tue Nov 19, 2019 11:23 am
Si grazie volentieri, la tua è molto bella.
avanzi una birra :)
Jolumarali
Software: WlIP
Post by Jolumarali » Tue Nov 19, 2019 3:33 pm
Valerio
http://meteo-lignerolles.fr/plugins/contact/index.php
Valerio, puoi lasciarmi la tua email tramite questo link e ti invierò il file NOAA con Smash (servizio online)
Domani sarò via
Bonne soirée
Tigro11
Post by Tigro11 » Tue Nov 19, 2019 4:06 pm
Fatto .
Grazie mille
Valerio
Tigro11
Post by Tigro11 » Thu Nov 21, 2019 9:51 am
Perfetto, questo il risultato
Noaa
Noaa
link pagina: http://carlinometeo2.altervista.org/tem ... ?page=NOAA
Si potrebbe pensare a costruire un block per averlo integrato direttamente su meteotemplate.
Jolumarali
Software: WlIP
Post by Jolumarali » Thu Nov 21, 2019 10:03 am
Perfetto Valerio :)
Tigro11
Post by Tigro11 » Tue Nov 26, 2019 6:02 pm
hello guys, I wanted to ask for an info, how can I create the xml file that creates graphweather for reports by drawing data from the meteotemplate database?
Valerio
giando11
Station model: Davis pro 2
Software: Weatherlink
Post by giando11 » Fri Nov 24, 2023 10:18 am
hi anyone use this? i want to add this noaa report but read the data from meteotemplate
Post by davidefa » Sat Nov 25, 2023 5:14 pm
@Tigro11
Can you post an example of xml file generated by graphweather
