(Solved) Stickers not showing up at all
Posted: Thu Dec 12, 2019 1:55 am
by bthoven
I've setup meteotemplate. Most functions are working display without problem. I still have problem with sticker plugin. It doesn't show up at all. The folder/files permission are same as other meteotemplate folders/files. Any idea what I might have done wrong?
Re: Stickers not showing up at all
Posted: Fri Dec 13, 2019 5:22 am
by John B
bthoven, I'm not quite sure what you are trying to do.
Firstly, it is not designed to place in your web site, well it might work, but why bother..
Secondly, it is usually used as a 'signature' on forums such as this one.
Thirdly, have you thoroughly checked your coding?
This is mine:
[url=http://www.johnsblaxlandweather.id.au]
[img] http://www.johnsblaxlandweather.id.au/template/plugins/stickers/stickerInteractive.php?type=interactive&color=white&dualUnits=1&border=2&image=random&text=%20%20%20%20%20G'day,%20from%20Blaxland%20Weather,%20NSW,%20Australia[/img][/url]
Of course you will need to amend that in accordance with the instructions Jáchym has provided in the settings for the plug-in, in order to produce the result you desire.
Posted: Sat Dec 14, 2019 8:07 am
by bthoven
Thanks. I know the stickers are for what you said. It worked when I had meteotemplate installed on my old server. It just does not work at all on my new server. The above screenshot was from the stickers plugin page itself which is supposed to display all sample stickers.
Posted: Tue Dec 17, 2019 4:59 am
by bthoven
update: it is working now. My php7.2, ubuntu 18.04, needs GD extension to make it work.
sudo apt-get install php7.2-gd
