Wind gust with plugins WLIP
PNCATTE
Software: WLIP
Post by PNCATTE » Mon Dec 30, 2019 9:33 am
With the WLIP plugin the wind gusts do not match
When I check what WEATHERLINK sends me:
https://api.weatherlink.com/v1/NoaaExt. ... rie69820&a
There is only one line that takes the bursts from the line above
<Wind_ten_min_gust_mph> 5.0 </ wind_ten_min_gust_mph>
But this value is not taken over for the database
How to take into account this line which seems to correspond to the last 10 minutes
Thanks in advance for the help
My site :http://www.fleurie-meteolive.ovh
cordially
Olinet
Station model: Vantage Pro 2
Re: Wind gust with plugins WLIP
Post by Olinet » Wed Jan 01, 2020 11:26 am
In your file ..plugins\WIIP\wlIPupdate.php ,
you have the link between the database fields and the xml tags of the weatherlink API:
For Gust you should have:
$rawUpdate['G'] = floatval($xml->wind_mph)*1.609; //km/h
which you can replace with:
$rawUpdate['G'] = floatval($xml->davis_current_observation->wind_ten_min_gust_mph)*1.609; //km/h
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Wed Jan 01, 2020 5:59 pm
Bonjour
Ma question ton cron est réglé à combien de minutes.
perso : 1 minute
et sur data
sur weatherlink il n'y a pas les rafales et meteotemplateLive.txt
ce qu'il enregistre
{"T":5.9,"H":93,"P":1032.6,"B":221,"W":1.609,"G":4.827,"R":0.20066,"RR":0,"S":0,"U":1577901058,"TIN":22.2,"HIN":38,"SW":"wlIP","TTime":1577901105,"HTime":1577901105,"PTime":1577901105,"BTime":1577901105,"WTime":1577901105,"GTime":1577901105,"RTime":1577901105,"RRTime":1577901105,"STime":1577901105,"UTime":1577901105,"TINTime":1577901105,"HINTime":1577901105,"SWTime":1577901105,"D":4.8,"DTime":1577901105,"A":4.4,"ATime":1577901105}
Donc c'est une idée, si tu mets le cron sur 1 minute, tu as des chance que ta rafale maxi soit enregistrée vu qu''elles ont enregistrée dans alldata toutes les cinq minutes.
perso cela fonctionne (Tout cela est une observation) à voir
si ton cron est déjà sur 1 minute , aucune autre idée, en espérant que tu es compris HUmmm
après tout cela Bonne et heureuse année
Olinet
Post by Olinet » Wed Jan 01, 2020 7:15 pm
je confirme, avec le Cron sur 1 minute, cela va fonctionner de la manière que tu décris Jolumarali
Jolumarali
Software: WlIP
Post by Jolumarali » Thu Jan 02, 2020 6:52 am
Bonjour
petite modif de mon current
PNCATTE
Software: WLIP
Post by PNCATTE » Sat Jan 04, 2020 8:18 am
After modifying the file:
..plugins \ WIIP \ wlIPupdate.php
line:
$ rawUpdate ['G'] = floatval ($ xml-> davis_current_observation-> wind_ten_min_gust_mph) * 1.609; // km / h
and set the CRON to 1 minute
gusts are taken into account
Putting the CRON one minute also allows to have the mini / maxi each time before they were all identical
Thank you again for your precious help for having a fair database.
Happy new year 2020
Pascal
PNCATTE
Software: WLIP
Post by PNCATTE » Sat Jan 04, 2020 8:23 am
Bonjour,
Après avoir modifié le fichier:
ligne:
et réglez le CRON sur 1 minute
les rafales sont bien prises en compte
Mettre le CRON une minute permet aussi d'avoir les mini / maxi à chaque releves de 5 minutes pour ma base avant elles étaient toutes identiques.
Merci encore pour votre aide précieuse pour avoir une base de données juste
Bonne année 2020
Pascal
