New Particulate Monitor Block attached
MJW
Station model: AW WS-2000ish
Post by MJW » Fri Feb 07, 2020 4:41 am
While I was fixing the api files to allow more than 4 temp/humidity sensors in the extra sensor table, I went ahead and created a block that will read PM2.5 data from the extra sensor table, if you have the sensor. I used the gust icon, I put a PM icon in the attached zip but never could figure out how to get it to show up. Just like all other blocks, the block folder in the attached zip goes with the rest of your block folders. Enjoy!
extraPP.zip
ExtraPP block folder
(11.55 KiB) Downloaded 497 times
So many trees in NJ!
Re: New Particulate Monitor Block attached
Post by andyk1 » Sat Feb 08, 2020 10:21 am
Thanks MJW!!!
Will let you know once I get it set up and going in the next few days. Working on to many things at the same time and getting nothing done... :D
