Evapotranspiration plugin wrong?
Posted: Sun Sep 17, 2017 4:30 pm
by nikokara - BANNED
Hi
Maybe here is samthing wrong
The ETplugin shows constant 5m/s as average wind speed. I really have 0.3 m/s for today.
If i try manualy to enter the 0.3 value Et is the same, i also input 50 m/s Et is the same, even if i input 500m/s (exceptet so far 4000-6000 mm water.
Re: Evapotranspiration plugin wrong?
Posted: Sun Sep 17, 2017 4:34 pm
Sorry i posted in the blocks problems. This is an plugin problem
Sorry :(
Posted: Sun Sep 17, 2017 5:10 pm
The ET value depends especially on solar radiation, if solar is 0 then it will not change no matter which parameter you change
Posted: Sun Sep 17, 2017 5:39 pm
Thank you Yachim for the reply
Can you please move this in the plugins group
My averages are
28.2 °C
82.8 °F
39.4 % Hum
0.3 m/s Wind speed
1.1 km/h
0.7 mph
0.6 kt
1013.0 hPa Presure
29.91 inHg
250 W m-2 SR <-----
4.0 m Alt
13.1 ft
37.95 N Lat
17.09.2017 Date
This gives 4.216 mm
the same as AWS=40m/s
The wind speed is very importand in the FAO Penman-Monteith equation!!!
Maybe more important than solar radiation
Posted: Sun Sep 17, 2017 6:25 pm
The equation is taken directly from NOAA, the wind speed is converted to 2m height, I really dont remember how exactly it is calculated, you can look at the code, but AFAI remeber I checked it and it more or less worked
Posted: Tue Sep 19, 2017 9:45 pm
Hi Jachim
I checked the code.
In index.php of ET
@ line 59 and @ line 208, i have changed the variable $w to $f, (from the class file)
and now it swows the average daily wind speed correct.
I have not checked or compared the Eto result yet. I will try to import data to an Eto programm
and post the results here.
Posted: Wed Sep 20, 2017 8:44 am
ok thanks
Posted: Sat Sep 23, 2017 7:26 am
Hi Jachym
I have compared the results with FAOs Eto calculator
Here the screenshots
with 0.3 m/s wind speed
and here with zero wind
tsitat --> wind speed totaly ignored (not calculated)
ps i can send you the Eto programm if you want.
have i nice Day :)
