statisticsDay (default) is not updated
ph2
The standard plugin statisticsDay is not updated if you change the time span and press the button again. You have to press the value symbol (temperature, etc.) again. The days are incorrect for "all values": These start with day 0 in every month, i.e. the date values must be increased by 1 The same errors are with statisticsNight.
