UK Warnings Block
UK Warnings Block
Post by Johnny » Sat Jan 16, 2021 10:05 am
Has anyone else in the UK found the Weather Warnings block stopped working in the past few days?
Screenshot_2021-01-16 Watford Weather.png (10.94 KiB) Viewed 18362 times
Re: UK Warnings Block
Post by Johnny » Sat Jan 16, 2021 9:22 pm
All working again :)
Screenshot_2021-01-16a Watford Weather.png (13.16 KiB) Viewed 18354 times
Post by Johnny » Sun Jan 17, 2021 12:43 pm
Wah, it's gone wrong again, seems to go wrong when a weather warning is issued.
Screenshot_2021-01-17 Watford Weather.png (11.8 KiB) Viewed 18350 times
WessexWeather
Post by WessexWeather » Wed Jan 20, 2021 1:03 pm
Yes I've noticed the same. Perhaps the data source has changed?
I've also noticed that the warningsEUregions block no longer displays UK weather warnings. Brexit perhaps?
It would be nice to get one or both of these important blocks working...
Simon (WessexWeather)
Post by davidefa » Wed Jan 20, 2021 4:53 pm
I think the xml reply has changed.
You can try the attached block ( but I don't know how it should display )
warningsUK_2.2.zip
(2.75 KiB) Downloaded 1013 times
Post by Johnny » Sat Jan 23, 2021 11:42 am
Hi Davidefa,
Thank you for the fix on the Weather Warnings block for the UK, I downloaded your block update, although it does work, it lists all weather warnings for the entire United Kingdom, selecting a specific area like 'se' for south-east does not unfortunately work.
I will continue to use it, as it's better to have this than nothing at all.
Many, many thanks - John
Screenshot_2021-01-23 Watford Weather.png (126.43 KiB) Viewed 18293 times
WessexWeather
Post by WessexWeather » Sat Jan 23, 2021 11:52 am
Apparently the errors are due to an error caused by the retirement of Adobe Flash, which has affected submission of the warnings from the Met Office to Meteoalarm. A fix is underway as we speak, so hang in there!
Post by davidefa » Sat Jan 23, 2021 4:06 pm
Hi John, I think you are seeing the previously cached data.
Nonetheless I have updated the block, so that it starts closed ( to be consistent with the behaviour of the other warning blocks )
warningsUK_2.3.zip
(2.88 KiB) Downloaded 1008 times
Post by Johnny » Sat Jan 23, 2021 7:13 pm
WessexWeather wrote: Sat Jan 23, 2021 11:52 am Apparently the errors are due to an error caused by the retirement of Adobe Flash, which has affected submission of the warnings from the Met Office to Meteoalarm. A fix is underway as we speak, so hang in there!
The dreaded Flash, thanks Simon.
Post by Johnny » Sat Jan 23, 2021 7:28 pm
davidefa wrote: Sat Jan 23, 2021 4:06 pm Hi John, I think you are seeing the previously cached data.
Hi Davidefa, thanks for the updated version, as you say it's now opens collapsed. But the previous version you did seems to have almost sorted itself out, so I have gone back to that one, personally I prefer it not collapsed. Thanks so much for your help on this, really appreciated.
Screenshot_2021-01-23 Watford Weather B.png (33.29 KiB) Viewed 18276 times
