UK Warnings Block
Posted: Sat Jan 16, 2021 10:05 am
by Johnny
Has anyone else in the UK found the Weather Warnings block stopped working in the past few days?
- Screenshot_2021-01-16 Watford Weather.png (10.94 KiB) Viewed 18345 times
Re: UK Warnings Block
Posted: Sat Jan 16, 2021 9:22 pm
by Johnny
All working again
- Screenshot_2021-01-16a Watford Weather.png (13.16 KiB) Viewed 18337 times
Posted: Sun Jan 17, 2021 12:43 pm
by Johnny
Wah, it's gone wrong again, seems to go wrong when a weather warning is issued.
- Screenshot_2021-01-17 Watford Weather.png (11.8 KiB) Viewed 18333 times
Posted: Wed Jan 20, 2021 1:03 pm
by WessexWeather
Yes I've noticed the same. Perhaps the data source has changed?
I've also noticed that the warningsEUregions block no longer displays UK weather warnings. Brexit perhaps?
It would be nice to get one or both of these important blocks working...
Posted: Wed Jan 20, 2021 4:53 pm
I think the xml reply has changed.
You can try the attached block ( but I don't know how it should display )
Posted: Sat Jan 23, 2021 11:42 am
by Johnny
Hi Davidefa,
Thank you for the fix on the Weather Warnings block for the UK, I downloaded your block update, although it does work, it lists all weather warnings for the entire United Kingdom, selecting a specific area like 'se' for south-east does not unfortunately work.
I will continue to use it, as it's better to have this than nothing at all.
Many, many thanks - John
- Screenshot_2021-01-23 Watford Weather.png (126.43 KiB) Viewed 18276 times
Posted: Sat Jan 23, 2021 11:52 am
by WessexWeather
Apparently the errors are due to an error caused by the retirement of Adobe Flash, which has affected submission of the warnings from the Met Office to Meteoalarm. A fix is underway as we speak, so hang in there!
Posted: Sat Jan 23, 2021 4:06 pm
Hi John, I think you are seeing the previously cached data.
Nonetheless I have updated the block, so that it starts closed ( to be consistent with the behaviour of the other warning blocks )
Posted: Sat Jan 23, 2021 7:13 pm
by Johnny
WessexWeather wrote: ↑Sat Jan 23, 2021 11:52 am
The dreaded Flash, thanks Simon.
Posted: Sat Jan 23, 2021 7:28 pm
by Johnny
davidefa wrote: ↑Sat Jan 23, 2021 4:06 pm
Hi Davidefa, thanks for the updated version, as you say it's now opens collapsed. But the previous version you did seems to have almost sorted itself out, so I have gone back to that one, personally I prefer it not collapsed. Thanks so much for your help on this, really appreciated.
