Forecast block - Yr.no
meteocharleroi
Software: Weatherlink live
Post by meteocharleroi » Wed Jan 27, 2021 7:06 pm
I try to setup the yr.no part in the forecast block.
I see that you have to put the URL like this :
https://www.yr.no/place and you have to find the place to the yr.no site.
But it seems the site have change because you can't find https://www.yr.no/place
I find this for my place : https://www.yr.no/en/forecast/daily-tab ... ce/Leernes
But if I try : https://www.yr.no/place/Belgium/Walloni ... ce/Leernes it is not working.
How do you find the correct URL ?
Thanks.
Asobig
Software: Meteobridge (Red)
Re: Forecast block - Yr.no
Post by Asobig » Wed Jan 27, 2021 8:59 pm
1. goto yr.no
2. in the searchbox enter your town or city (lets say Amsterdam)
3. Click on the link that matches your hometown
4. look at the addressbar, it looks like:
https://www.yr.no/en/forecast/daily-table/2-2759794/Netherlands/North%20Holland/Gemeente%20Amsterdam/Amsterdam
5. select the part:
6. remove all the extra info so you get
Netherlands/North%20Holland/Amsterdam
(the format is country/ province/city)
7. Paste this part in the setup of the block so it looks like this:
https://www.yr.no/place/Netherlands/North%20Holland/Amsterdam/forecast.xml
or in your case:
https://www.yr.no/place/Belgium/Wallonia/Leernes/forecast.xml
If all went well you see a forecast on your site.
But i got bad news. In the header of forecast.xml is a message:
<apiChanges>
<!-- NB!!! Since we have no other options to contact our users of forecast.xml, we have decided to use this method to get your attention to some major changes with our API -->
<!-- In the first quarter next year, forecast.xml and forecast_hour_by_hour.xml will be discontinued in favour of a newer JSON API. -->
<!-- Vi encourage you already now to switch to the new API. -->
<!-- There are a lot of changes, and you can read all the technical details in our new developer portal https://developer.yr.no -->
</apiChanges>
This means that in the near future the block on all Meteotemplate sites will stop working, Jachym has to change the block to use JSON.
meteocharleroi
Post by meteocharleroi » Wed Jan 27, 2021 9:14 pm
Asobig wrote: Wed Jan 27, 2021 8:59 pm 1. goto yr.no
5. select the part:
or in your case:
<apiChanges>
</apiChanges>
Thanks a lot.
I see that you are using wxsim blok.
Did you suceed to have the correct value for rain ?
If yes, how do you do that ?
Asobig
Post by Asobig » Thu Jan 28, 2021 7:32 am
yes, i use WXSIM.
But i can't remember if i changed anything to make it work, but these are the values in the settings file:
$showWxSimForecast = true;
$pathLatest = '../../../uploadwd/latest.csv';
$pathPlainText = '../../../uploadwd/plaintext.txt';
$categories = '0-4,4-8,8-12,12-16,16-20,20-24';
$maxDays = '2';
$decimalSeparator = ',';
$wxSimString = '';
Post by davidefa » Sat Jan 30, 2021 6:05 pm
In the meteogram block setup you should insert:
Leernes,Belgium/Wallonia/Leernes/
After chaging the setup you should always clear the cache ( otherwise you'll continue to see the previously cached data, this will lead you to think that every change you make takes no effect )
meteocharleroi
Post by meteocharleroi » Sat Jan 30, 2021 8:12 pm
Thanks a lot.
It works now.
brudars
Station model: Davis vantage pro 2
Post by brudars » Mon Oct 25, 2021 8:28 pm
What is with the yr.no forecast. url's are not working anymore.
Post by davidefa » Mon Oct 25, 2021 9:16 pm
If you are referring to the meteogram block you can find an updated version here.
hcorrin
Station model: Davis VP2
Post by hcorrin » Mon Oct 25, 2021 9:36 pm
neither the forecast or meteogram blocks are getting the data file this happened about 3 days ago but was working again later in the day
Post by davidefa » Mon Oct 25, 2021 10:07 pm
My bad, I confused the forecast and the meteogram blocks.
Now I see the forecast from yr.no is not working
It seems we have to update the block ( this is what I get ):
<deprecationWarning>
This service will be retired on February 1st, 2022. Please go to https://developer.yr.no/doc/guides/gett ... ecast-xml/ to get started with our new API. This service will have random interuptions until the final end of life date February 1st, 2022.
<scheduledServiceInterruptions>
<serviceDown>2021-09-27 06:00 - 18:00 UTC (12h)</serviceDown>
<serviceDown>2021-10-05 06:00 - 18:00 UTC (12h)</serviceDown>
<serviceDown>2021-10-15 06:00 - 18:00 UTC (12h)</serviceDown>
<serviceDown>2021-10-21 06:00 - 18:00 UTC (12h)</serviceDown>
<serviceDown>2021-10-25 06:00 - 06:00 UTC (24h)</serviceDown>
<serviceDown>2021-11-02 06:00 - 06:00 UTC (24h)</serviceDown>
<serviceDown>2021-11-10 06:00 - 06:00 UTC (24h)</serviceDown>
<serviceDown>2021-11-15 06:00 - 2021-11-17 06:00 UTC (48h)</serviceDown>
<serviceDown>2021-11-23 06:00 - 2021-11-25 06:00 UTC (48h)</serviceDown>
</scheduledServiceInterruptions>
<endOfLifeDate>2022-02-01</endOfLifeDate>
</deprecationWarning>
brudars
Post by brudars » Tue Oct 26, 2021 4:29 am
are you the creator of the block? when will the update be expected?
Post by davidefa » Tue Oct 26, 2021 8:37 am
brudars wrote: Tue Oct 26, 2021 4:29 am are you the creator of the block? when will the update be expected?
No, I'm not the author of the block, I've only done the same mod on the meteogram block. I've added to my todo list ( which is growing too rapidly )... so I won't hold the breath
Post by davidefa » Tue Jan 25, 2022 5:39 pm
ver 9.1
Updated to use Yr.No v2 api ( from next February 1st old xml format wont be supported anymore )
Need to rerun the setup ( as the location format changed, it is the same of meteogram block )
Format of YrNo location as following: Rome-Italy,lat=41.89193&lon=12.51133&altitude=20
( name,lat=xxx&lon=yyy&altitude=zzz )
download
chrimu
Station model: Homematic
Software: Homematic scripts
Post by chrimu » Fri Feb 04, 2022 12:52 pm
Thanks for your effort! In my case:
Beersel-Belgium,lat=50.76218&lon=4.30322&altitude=75
works fine for meteogram, but unfortunately leaves the YR.no forecast black. Cache was emptied.
Any clue?
Cheers, Christian
Post by davidefa » Fri Feb 04, 2022 2:34 pm
Could you provide the url of your site?
I tested your settings on my testing site and it works correctly, so there is something I don't understand completely.
Please, upload to the forecast block folder the attached script and run it ( homepage/blocks/forecast/forecastAjax1.php?service=yrNo&debug=9 ), I added only a few debug prints, it will not overwrite any script already present. What does it shows?
forecastAjax1_1.0.zip
(7.49 KiB) Downloaded 1246 times
Jolumarali
Station model: Vantage Vue
Software: WlIP
Post by Jolumarali » Fri Feb 04, 2022 3:00 pm
Hello Davide
Personally everything and OK
chrimu
Post by chrimu » Mon Feb 07, 2022 12:35 am
Hi Davide,
I tried Ajax1, but can't interpret the result...
root@CMAScommonB:/volume1/web/template/homepage/blocks/forecast# ./forecastAjax1.php?service=yrNo&debug=9
[1] 22648
root@CMAScommonB:/volume1/web/template/homepage/blocks/forecast# -ash: ./forecastAjax1.php?service=yrNo: No such file or directory
^C
[1]+  Exit 127                ./forecastAjax1.php?service=yrNo
My site is unfortunately on intranet only, and forecast meteoblue and darksky works. Just YR.no stays black. But in so far, don't waste time on it, it can stay as is...
Many thanks,
Christian
Post by davidefa » Tue Feb 08, 2022 12:37 am
Sorry for not being clear enough, you should call the script pointing your browser to ( replace ip_of_the_server and base_directory with appropriate values ):
 http://ip_of_the_server/base_directory/homepage/blocks/forecast/forecastAjax1.php?service=yrNo&debug=9
chrimu
Post by chrimu » Tue Feb 08, 2022 2:29 am
OK, here we go:
yrNoLocation=
Array ( [0] => Beersel-Belgium [1] => lat=50.76218&lon=4.30322&altitude=75 )
yrNoURL=https://api.met.no/weatherapi/locationforecast/2.0/compact?lat=50.76218&lon=4.30322&altitude=75
xmlYrNo=
Array ( [type] => Feature [geometry] => Array ( [type] => Point [coordinates] => Array ( [0] => 4.3032 [1] => 50.7622 [2] => 75 ) ) [properties] => Array ( [meta] => Array ( [updated_at] => 2022-02-06T22:01:39Z [units] => Array ( [air_pressure_at_sea_level] => hPa [air_temperature] => celsius [cloud_area_fraction] => % [precipitation_amount] => mm [relative_humidity] => % [wind_from_direction] => degrees [wind_speed] => m/s ) ) [timeseries] => Array ( [0] => Array ( [time] => 2022-02-07T01:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1013.4 [air_temperature] => 3.6 [cloud_area_fraction] => 23.4 [relative_humidity] => 77.2 [wind_from_direction] => 301.8 [wind_speed] => 7 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [1] => Array ( [time] => 2022-02-07T02:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1015.3 [air_temperature] => 3.6 [cloud_area_fraction] => 41.4 [relative_humidity] => 75.3 [wind_from_direction] => 299 [wind_speed] => 6.5 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [2] => Array ( [time] => 2022-02-07T03:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1016.9 [air_temperature] => 3.5 [cloud_area_fraction] => 12.5 [relative_humidity] => 72.8 [wind_from_direction] => 299.4 [wind_speed] => 6.4 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [3] => Array ( [time] => 2022-02-07T04:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1018.6 [air_temperature] => 3.1 [cloud_area_fraction] => 14.1 [relative_humidity] => 72.4 [wind_from_direction] => 300.6 [wind_speed] => 5.9 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [4] => Array ( [time] => 2022-02-07T05:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1020.1 [air_temperature] => 2.7 [cloud_area_fraction] => 21.1 [relative_humidity] => 74.5 [wind_from_direction] => 300.5 [wind_speed] => 5.4 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [5] => Array ( [time] => 2022-02-07T06:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1021.4 [air_temperature] => 2.3 [cloud_area_fraction] => 23.4 [relative_humidity] => 77.2 [wind_from_direction] => 290.6 [wind_speed] => 4.4 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [6] => Array ( [time] => 2022-02-07T07:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1022.6 [air_temperature] => 1.6 [cloud_area_fraction] => 13.3 [relative_humidity] => 80.9 [wind_from_direction] => 273.5 [wind_speed] => 3.8 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [7] => Array ( [time] => 2022-02-07T08:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1023.9 [air_temperature] => 1.9 [cloud_area_fraction] => 21.1 [relative_humidity] => 80.4 [wind_from_direction] => 266.3 [wind_speed] => 4.2 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [8] => Array ( [time] => 2022-02-07T09:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1025.1 [air_temperature] => 3.4 [cloud_area_fraction] => 89.8 [relative_humidity] => 77.5 [wind_from_direction] => 266.2 [wind_speed] => 4.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [9] => Array ( [time] => 2022-02-07T10:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1026.3 [air_temperature] => 5 [cloud_area_fraction] => 11.7 [relative_humidity] => 72.2 [wind_from_direction] => 277.5 [wind_speed] => 4.7 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [10] => Array ( [time] => 2022-02-07T11:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1026.9 [air_temperature] => 6.1 [cloud_area_fraction] => 8.6 [relative_humidity] => 65.4 [wind_from_direction] => 283.8 [wind_speed] => 5.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [11] => Array ( [time] => 2022-02-07T12:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1027.2 [air_temperature] => 6.7 [cloud_area_fraction] => 43 [relative_humidity] => 62.6 [wind_from_direction] => 277.3 [wind_speed] => 4.9 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [12] => Array ( [time] => 2022-02-07T13:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1027.5 [air_temperature] => 7.3 [cloud_area_fraction] => 51.6 [relative_humidity] => 60.1 [wind_from_direction] => 273.4 [wind_speed] => 5 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [13] => Array ( [time] => 2022-02-07T14:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1027.9 [air_temperature] => 7.4 [cloud_area_fraction] => 0.8 [relative_humidity] => 59 [wind_from_direction] => 269.3 [wind_speed] => 5.2 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [14] => Array ( [time] => 2022-02-07T15:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.2 [air_temperature] => 7.1 [cloud_area_fraction] => 0.8 [relative_humidity] => 59.6 [wind_from_direction] => 263 [wind_speed] => 4.9 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [15] => Array ( [time] => 2022-02-07T16:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.6 [air_temperature] => 6.2 [cloud_area_fraction] => 0 [relative_humidity] => 65 [wind_from_direction] => 257.7 [wind_speed] => 4.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [16] => Array ( [time] => 2022-02-07T17:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.7 [air_temperature] => 4.3 [cloud_area_fraction] => 13.3 [relative_humidity] => 72.1 [wind_from_direction] => 247.5 [wind_speed] => 3.5 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [17] => Array ( [time] => 2022-02-07T18:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.7 [air_temperature] => 3.7 [cloud_area_fraction] => 35.2 [relative_humidity] => 73.8 [wind_from_direction] => 238.8 [wind_speed] => 4 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [18] => Array ( [time] => 2022-02-07T19:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.8 [air_temperature] => 3.8 [cloud_area_fraction] => 21.1 [relative_humidity] => 73.8 [wind_from_direction] => 234.1 [wind_speed] => 4.5 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [19] => Array ( [time] => 2022-02-07T20:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.9 [air_temperature] => 3.6 [cloud_area_fraction] => 0.8 [relative_humidity] => 73.9 [wind_from_direction] => 231.2 [wind_speed] => 4.7 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [20] => Array ( [time] => 2022-02-07T21:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.2 [air_temperature] => 3.1 [cloud_area_fraction] => 12.5 [relative_humidity] => 78.7 [wind_from_direction] => 226 [wind_speed] => 4.8 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [21] => Array ( [time] => 2022-02-07T22:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.6 [air_temperature] => 3.2 [cloud_area_fraction] => 100 [relative_humidity] => 82.8 [wind_from_direction] => 226.9 [wind_speed] => 5.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.2 ) ) ) ) [22] => Array ( [time] => 2022-02-07T23:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.6 [air_temperature] => 4.5 [cloud_area_fraction] => 100 [relative_humidity] => 82.5 [wind_from_direction] => 229.7 [wind_speed] => 5.5 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.3 ) ) ) ) [23] => Array ( [time] => 2022-02-08T00:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.6 [air_temperature] => 4.9 [cloud_area_fraction] => 100 [relative_humidity] => 85.6 [wind_from_direction] => 228.4 [wind_speed] => 5.7 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.3 ) ) ) ) [24] => Array ( [time] => 2022-02-08T01:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.4 [air_temperature] => 5.6 [cloud_area_fraction] => 100 [relative_humidity] => 83.5 [wind_from_direction] => 225.8 [wind_speed] => 6.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.4 ) ) ) ) [25] => Array ( [time] => 2022-02-08T02:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.4 [air_temperature] => 5.7 [cloud_area_fraction] => 100 [relative_humidity] => 82.7 [wind_from_direction] => 224.3 [wind_speed] => 5.8 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.3 ) ) ) ) [26] => Array ( [time] => 2022-02-08T03:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.8 [air_temperature] => 6.2 [cloud_area_fraction] => 100 [relative_humidity] => 83 [wind_from_direction] => 221.9 [wind_speed] => 6.3 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) [details] => Array ( [precipitation_amount] => 0.2 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.4 ) ) ) ) [27] => Array ( [time] => 2022-02-08T04:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.6 [air_temperature] => 6.5 [cloud_area_fraction] => 100 [relative_humidity] => 84.3 [wind_from_direction] => 224.2 [wind_speed] => 6.5 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.3 ) ) ) ) [28] => Array ( [time] => 2022-02-08T05:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.8 [air_temperature] => 7 [cloud_area_fraction] => 100 [relative_humidity] => 86.7 [wind_from_direction] => 228.6 [wind_speed] => 6.8 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.4 ) ) ) ) [29] => Array ( [time] => 2022-02-08T06:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.7 [air_temperature] => 7.3 [cloud_area_fraction] => 100 [relative_humidity] => 88.5 [wind_from_direction] => 229.4 [wind_speed] => 6.8 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) [details] => Array ( [precipitation_amount] => 0.6 ) ) ) ) [30] => Array ( [time] => 2022-02-08T07:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.8 [air_temperature] => 7.5 [cloud_area_fraction] => 100 [relative_humidity] => 89.5 [wind_from_direction] => 229.4 [wind_speed] => 7 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) [details] => Array ( [precipitation_amount] => 0.7 ) ) ) ) [31] => Array ( [time] => 2022-02-08T08:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.1 [air_temperature] => 7.8 [cloud_area_fraction] => 100 [relative_humidity] => 90.2 [wind_from_direction] => 230.9 [wind_speed] => 6.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrainshowers_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) [details] => Array ( [precipitation_amount] => 0.2 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) [details] => Array ( [precipitation_amount] => 0.7 ) ) ) ) [32] => Array ( [time] => 2022-02-08T09:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.3 [air_temperature] => 8.4 [cloud_area_fraction] => 100 [relative_humidity] => 89.7 [wind_from_direction] => 236.8 [wind_speed] => 6.2 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrainshowers_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) [details] => Array ( [precipitation_amount] => 0.6 ) ) ) ) [33] => Array ( [time] => 2022-02-08T10:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.4 [air_temperature] => 9.2 [cloud_area_fraction] => 65.6 [relative_humidity] => 88.4 [wind_from_direction] => 241 [wind_speed] => 6.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) [details] => Array ( [precipitation_amount] => 0.2 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) [details] => Array ( [precipitation_amount] => 0.6 ) ) ) ) [34] => Array ( [time] => 2022-02-08T11:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.4 [air_temperature] => 10.4 [cloud_area_fraction] => 96.9 [relative_humidity] => 83.4 [wind_from_direction] => 253.7 [wind_speed] => 7.7 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => rain ) [details] => Array ( [precipitation_amount] => 0.3 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.4 ) ) ) ) [35] => Array ( [time] => 2022-02-08T12:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.2 [air_temperature] => 10.1 [cloud_area_fraction] => 100 [relative_humidity] => 86.4 [wind_from_direction] => 236.2 [wind_speed] => 6.3 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [36] => Array ( [time] => 2022-02-08T13:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.9 [air_temperature] => 9.4 [cloud_area_fraction] => 100 [relative_humidity] => 89.7 [wind_from_direction] => 235.8 [wind_speed] => 6.4 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [37] => Array ( [time] => 2022-02-08T14:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.8 [air_temperature] => 10.3 [cloud_area_fraction] => 59.4 [relative_humidity] => 85.4 [wind_from_direction] => 247.2 [wind_speed] => 7.2 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [38] => Array ( [time] => 2022-02-08T15:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.6 [air_temperature] => 10.7 [cloud_area_fraction] => 99.2 [relative_humidity] => 81.1 [wind_from_direction] => 245.5 [wind_speed] => 5.3 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [39] => Array ( [time] => 2022-02-08T16:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.6 [air_temperature] => 10.4 [cloud_area_fraction] => 98.4 [relative_humidity] => 82 [wind_from_direction] => 234.7 [wind_speed] => 4.7 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [40] => Array ( [time] => 2022-02-08T17:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029 [air_temperature] => 9.7 [cloud_area_fraction] => 98.4 [relative_humidity] => 83.3 [wind_from_direction] => 236 [wind_speed] => 5.2 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [41] => Array ( [time] => 2022-02-08T18:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.3 [air_temperature] => 8.9 [cloud_area_fraction] => 83.6 [relative_humidity] => 83.6 [wind_from_direction] => 232.9 [wind_speed] => 5 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [42] => Array ( [time] => 2022-02-08T19:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.6 [air_temperature] => 8.2 [cloud_area_fraction] => 71.9 [relative_humidity] => 84.8 [wind_from_direction] => 235.9 [wind_speed] => 5.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [43] => Array ( [time] => 2022-02-08T20:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.7 [air_temperature] => 7.7 [cloud_area_fraction] => 53.1 [relative_humidity] => 85.1 [wind_from_direction] => 234.5 [wind_speed] => 5.2 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [44] => Array ( [time] => 2022-02-08T21:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.5 [air_temperature] => 7.8 [cloud_area_fraction] => 100 [relative_humidity] => 86.9 [wind_from_direction] => 232.9 [wind_speed] => 5.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [45] => Array ( [time] => 2022-02-08T22:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.5 [air_temperature] => 8.1 [cloud_area_fraction] => 100 [relative_humidity] => 90.4 [wind_from_direction] => 228.3 [wind_speed] => 4.8 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [46] => Array ( [time] => 2022-02-08T23:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.2 [air_temperature] => 8.2 [cloud_area_fraction] => 100 [relative_humidity] => 91.3 [wind_from_direction] => 224.3 [wind_speed] => 5 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [47] => Array ( [time] => 2022-02-09T00:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.9 [air_temperature] => 8.2 [cloud_area_fraction] => 100 [relative_humidity] => 89.9 [wind_from_direction] => 218.5 [wind_speed] => 5.2 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [48] => Array ( [time] => 2022-02-09T01:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.8 [air_temperature] => 8.3 [cloud_area_fraction] => 100 [relative_humidity] => 86.5 [wind_from_direction] => 223.6 [wind_speed] => 5.6 ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [49] => Array ( [time] => 2022-02-09T02:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.8 [air_temperature] => 8.1 [cloud_area_fraction] => 93 [relative_humidity] => 86.1 [wind_from_direction] => 224.3 [wind_speed] => 5.1 ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [50] => Array ( [time] => 2022-02-09T03:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.3 [air_temperature] => 7.6 [cloud_area_fraction] => 100 [relative_humidity] => 87.2 [wind_from_direction] => 219 [wind_speed] => 4.8 ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [51] => Array ( [time] => 2022-02-09T04:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.1 [air_temperature] => 7.3 [cloud_area_fraction] => 100 [relative_humidity] => 87.5 [wind_from_direction] => 222.8 [wind_speed] => 5.3 ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [52] => Array ( [time] => 2022-02-09T05:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1027.9 [air_temperature] => 6.7 [cloud_area_fraction] => 100 [relative_humidity] => 87.5 [wind_from_direction] => 218.5 [wind_speed] => 5.6 ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [53] => Array ( [time] => 2022-02-09T06:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1027.9 [air_temperature] => 6 [cloud_area_fraction] => 94.5 [relative_humidity] => 90.1 [wind_from_direction] => 215.8 [wind_speed] => 5.4 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [54] => Array ( [time] => 2022-02-09T07:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028 [air_temperature] => 5.7 [cloud_area_fraction] => 50.8 [relative_humidity] => 91.1 [wind_from_direction] => 217.1 [wind_speed] => 5.1 ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [55] => Array ( [time] => 2022-02-09T08:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028.3 [air_temperature] => 5.2 [cloud_area_fraction] => 96.9 [relative_humidity] => 93.8 [wind_from_direction] => 216.4 [wind_speed] => 5.1 ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [56] => Array ( [time] => 2022-02-09T09:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028 [air_temperature] => 5.8 [cloud_area_fraction] => 38.3 [relative_humidity] => 90 [wind_from_direction] => 206.9 [wind_speed] => 4.7 ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [57] => Array ( [time] => 2022-02-09T10:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1027.8 [air_temperature] => 7.2 [cloud_area_fraction] => 39.8 [relative_humidity] => 83.9 [wind_from_direction] => 208.8 [wind_speed] => 5.2 ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [58] => Array ( [time] => 2022-02-09T11:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1027.6 [air_temperature] => 8.6 [cloud_area_fraction] => 18.7 [relative_humidity] => 79.9 [wind_from_direction] => 212 [wind_speed] => 5.2 ) ) [next_1_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [59] => Array ( [time] => 2022-02-09T12:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1027.2 [air_temperature] => 9.8 [cloud_area_fraction] => 1.6 [relative_humidity] => 78.1 [wind_from_direction] => 216.8 [wind_speed] => 5.2 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [60] => Array ( [time] => 2022-02-09T18:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1025.4 [air_temperature] => 7 [cloud_area_fraction] => 17.2 [relative_humidity] => 89 [wind_from_direction] => 202.1 [wind_speed] => 4 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [61] => Array ( [time] => 2022-02-10T00:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1024.6 [air_temperature] => 3.3 [cloud_area_fraction] => 64.8 [relative_humidity] => 94.9 [wind_from_direction] => 213.9 [wind_speed] => 3.6 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [62] => Array ( [time] => 2022-02-10T06:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1022.7 [air_temperature] => 2.9 [cloud_area_fraction] => 100 [relative_humidity] => 96.9 [wind_from_direction] => 218.4 [wind_speed] => 4 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.3 ) ) ) ) [63] => Array ( [time] => 2022-02-10T12:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1024.1 [air_temperature] => 6 [cloud_area_fraction] => 100 [relative_humidity] => 90.5 [wind_from_direction] => 292.1 [wind_speed] => 3.3 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [64] => Array ( [time] => 2022-02-10T18:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1026.1 [air_temperature] => 3.9 [cloud_area_fraction] => 100 [relative_humidity] => 75.2 [wind_from_direction] => 271.2 [wind_speed] => 2.7 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [65] => Array ( [time] => 2022-02-11T00:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1028 [air_temperature] => 1.5 [cloud_area_fraction] => 100 [relative_humidity] => 86.1 [wind_from_direction] => 259.1 [wind_speed] => 2.4 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [66] => Array ( [time] => 2022-02-11T06:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.9 [air_temperature] => -0.9 [cloud_area_fraction] => 14.8 [relative_humidity] => 95.7 [wind_from_direction] => 262.8 [wind_speed] => 1.7 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [67] => Array ( [time] => 2022-02-11T12:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1033.1 [air_temperature] => 6.9 [cloud_area_fraction] => 29.7 [relative_humidity] => 65.9 [wind_from_direction] => 308 [wind_speed] => 2.9 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [68] => Array ( [time] => 2022-02-11T18:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1034.3 [air_temperature] => 1.8 [cloud_area_fraction] => 0.8 [relative_humidity] => 87 [wind_from_direction] => 320.2 [wind_speed] => 2.3 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [69] => Array ( [time] => 2022-02-12T00:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1035.7 [air_temperature] => -2.8 [cloud_area_fraction] => 0 [relative_humidity] => 96.6 [wind_from_direction] => 237.5 [wind_speed] => 2 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [70] => Array ( [time] => 2022-02-12T06:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1035.1 [air_temperature] => -3 [cloud_area_fraction] => 100 [relative_humidity] => 98 [wind_from_direction] => 200.3 [wind_speed] => 1.8 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [71] => Array ( [time] => 2022-02-12T12:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1035.8 [air_temperature] => 3.6 [cloud_area_fraction] => 98.4 [relative_humidity] => 84.9 [wind_from_direction] => 212.6 [wind_speed] => 1.8 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [72] => Array ( [time] => 2022-02-12T18:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1033.6 [air_temperature] => 3.7 [cloud_area_fraction] => 79.7 [relative_humidity] => 79.9 [wind_from_direction] => 19.7 [wind_speed] => 0.9 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_night ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [73] => Array ( [time] => 2022-02-13T00:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1032.6 [air_temperature] => -2.3 [cloud_area_fraction] => 0 [relative_humidity] => 90 [wind_from_direction] => 155.9 [wind_speed] => 2 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [74] => Array ( [time] => 2022-02-13T06:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1029.1 [air_temperature] => -3.2 [cloud_area_fraction] => 0 [relative_humidity] => 85.8 [wind_from_direction] => 161.4 [wind_speed] => 2.8 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [75] => Array ( [time] => 2022-02-13T12:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1025.6 [air_temperature] => 5.9 [cloud_area_fraction] => 0 [relative_humidity] => 55.2 [wind_from_direction] => 164.3 [wind_speed] => 2.9 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_day ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [76] => Array ( [time] => 2022-02-13T18:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1021 [air_temperature] => 1.7 [cloud_area_fraction] => 0 [relative_humidity] => 75.5 [wind_from_direction] => 163.6 [wind_speed] => 3.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => clearsky_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [77] => Array ( [time] => 2022-02-14T00:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1018.3 [air_temperature] => 2 [cloud_area_fraction] => 0 [relative_humidity] => 90.2 [wind_from_direction] => 196.4 [wind_speed] => 4.6 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [78] => Array ( [time] => 2022-02-14T06:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1014.9 [air_temperature] => 3.9 [cloud_area_fraction] => 100 [relative_humidity] => 91.2 [wind_from_direction] => 197.2 [wind_speed] => 3.6 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrainshowers_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) [details] => Array ( [precipitation_amount] => 0.8 ) ) ) ) [79] => Array ( [time] => 2022-02-14T12:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1013.2 [air_temperature] => 5.6 [cloud_area_fraction] => 100 [relative_humidity] => 88.4 [wind_from_direction] => 211.7 [wind_speed] => 5.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrainshowers_day ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => rainshowers_day ) [details] => Array ( [precipitation_amount] => 1.5 ) ) ) ) [80] => Array ( [time] => 2022-02-14T18:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1018 [air_temperature] => 4.1 [cloud_area_fraction] => 35.2 [relative_humidity] => 92.4 [wind_from_direction] => 275.6 [wind_speed] => 4.8 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => fair_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [81] => Array ( [time] => 2022-02-15T00:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1020.8 [air_temperature] => 1.2 [cloud_area_fraction] => 0 [relative_humidity] => 92 [wind_from_direction] => 224.9 [wind_speed] => 3.7 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => partlycloudy_night ) [details] => Array ( [precipitation_amount] => 0 ) ) ) ) [82] => Array ( [time] => 2022-02-15T06:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1020 [air_temperature] => 1.5 [cloud_area_fraction] => 100 [relative_humidity] => 88.9 [wind_from_direction] => 201.7 [wind_speed] => 6.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => lightrain ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => cloudy ) [details] => Array ( [precipitation_amount] => 0.1 ) ) ) ) [83] => Array ( [time] => 2022-02-15T12:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1017.8 [air_temperature] => 5.8 [cloud_area_fraction] => 100 [relative_humidity] => 82.2 [wind_from_direction] => 198.7 [wind_speed] => 7.1 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => rain ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => rain ) [details] => Array ( [precipitation_amount] => 1.6 ) ) ) ) [84] => Array ( [time] => 2022-02-15T18:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1012.3 [air_temperature] => 6 [cloud_area_fraction] => 100 [relative_humidity] => 88.9 [wind_from_direction] => 209.4 [wind_speed] => 10 ) ) [next_12_hours] => Array ( [summary] => Array ( [symbol_code] => rain ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => rain ) [details] => Array ( [precipitation_amount] => 3 ) ) ) ) [85] => Array ( [time] => 2022-02-16T00:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1007.1 [air_temperature] => 7.5 [cloud_area_fraction] => 100 [relative_humidity] => 91.1 [wind_from_direction] => 214.7 [wind_speed] => 10.6 ) ) [next_6_hours] => Array ( [summary] => Array ( [symbol_code] => rain ) [details] => Array ( [precipitation_amount] => 1.6 ) ) ) ) [86] => Array ( [time] => 2022-02-16T06:00:00Z [data] => Array ( [instant] => Array ( [details] => Array ( [air_pressure_at_sea_level] => 1004.1 [air_temperature] => 11.3 [cloud_area_fraction] => 100 [relative_humidity] => 89 [wind_from_direction] => 229 [wind_speed] => 11.3 ) ) ) ) ) ) )
Cheers, C.
Post by davidefa » Tue Feb 08, 2022 11:18 pm
Ok, tanks for testing... could you replace the forecastAjax.php of the block with the attached one, delete the cache content, and try reloading the homepage/forecast block?
If it does not show correctly does it show any error in the firefox/chrome developer's console ( in firefox menu' Tools->Browser Tools->Web Developer Tools select the Console tab )?
forecastAjax_1.1.zip
(7.7 KiB) Downloaded 993 times
chrimu
Post by chrimu » Sat Feb 12, 2022 10:01 pm
Thanks! the YR part of the block is still black. Console says YR lodaing failure with result 500.
I'd really say leave it for what I'm concerened. Too much other things going on ;-)
Cheers, Christian
