updated gfs block
updated gfs block
Post by davidefa » Sat Jan 30, 2021 10:24 pm
ver2.2
I have updated the gfs block to show the maps again ( as maps were disabled in version 2.1 )
ver2.3
added an option to limit the number of 'runs' visualized ( as runs 33 and 34 generally screw up everything )
ver2.4
- fixes due to changes in source
- added option to show cumulative rain or 'instant rain'
gfs_2.4.zip
(11.74 KiB) Downloaded 816 times
gfs_2.3.zip
(11.15 KiB) Downloaded 643 times
gfs_2.2.zip
(11.26 KiB) Downloaded 618 times
RobRead
Re: updated gfs block
Post by RobRead » Tue Aug 03, 2021 1:10 am
added "Southern Hemesphere"
inserted
<option value="polar"><?php echo lang('southern hemisphere','c')?></option>
<optgroup label="<?php echo lang('australasia','c')?>">
<option value="australia" selected><?php echo lang('australia','c')?></option>
<option value="new_zealand"><?php echo lang('new zealand','c')?></option>
</optgroup>
above
<option value="polar"><?php echo lang('northern hemisphere','c')?></option>
and altered
else{
return "polar";
to
else{
return "australia";
to select Australia as default.
Daali
Station model: Ecowitt GW1002
Post by Daali » Tue Aug 03, 2021 2:02 am
You 2 dudes are killing it!. Thank you both for your work
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
WH41 PM2.5 Air Quality
WH45 PM2.5/10/Co2 Air Quality
WN34S Soil temperature
WH31SM Soil Moisture
Julius
Software: meteobridge
Post by Julius » Tue Jan 09, 2024 8:32 am
This block has an issue not showing minus zero degrees values (when the windrose block is used?)
