Hi Jachym,
Would it be possible to create a plug-in that pulls data from the WeatherFlow API, much like you have done with the Netatmo plugin?
I would love to be able to create a separate Meteotemplate installation for my WeatherFlow Tempest.
Another option would be if Boris allowed more than one instance of Meteotemplate to be run from a Meteobridge (which supports WeatherFlow) but this is currently not possible.
How about it?
WeatherFlow plugin
- WessexWeather
WeatherFlow plugin
Simon (WessexWeather)
Re: WeatherFlow plugin
I think it can be done, do you have a demo key to access the api ( or do you have a few responses records from the rest api to work on )?
snow
Hi.
I too would be very interested in the possibility of having a plugin to use the Tempest Weather Flow API. I will receive this station shortly and the only way to use it with meteotemplate is to send the data to Wunderground and create a CronJob. I find this method quite complex and not very stable. If a plugin were available, considering the wide diffusion that this weather station is having worldwide, it would be really useful. Here is a link that could be helpful, containing information about the API of this weather station: https://weatherflow.github.io/Tempest/api/
Thank you very much if you will be able to create this plugin!
I need an 'access token' to develop/test the plugin.
Create one following this post ( you can revoke it successively ) and it pm to me.
snow
I just sent you a PM with my personal API key. Thank you very much!
snow
Hi! How is the implementation of the plugin going? Can I help in any way? Thanks in advance and see you soon!
