updated extraT block, new allSensors block
Posted: Mon May 10, 2021 8:07 pm
Updated the extraT block:
- it can show data from any temperature sensor ( T, D, A, TIN, T1-T8, TS1-TS8, LT1-LT8... )
( need to specify the 'full name' of the sensor )
Added also a block ( allSensors ) to show the value from any sensor ( not only temperature sensor )
Re: updated extraT block, new allSensors block
Posted: Wed May 12, 2021 12:01 pm
by meteolopik
Thanks a lot!
Posted: Wed Jun 15, 2022 2:40 pm
by xBenny
Hi, I have a problem with the encoding of the allsensors block. I tried to change the encoding of individual files to both CP1250 and UTF8 no BOM, but the problem is still the same. Any advice? Thanks
Right title is "Externí čidla"
https://www.pocasi-klabava.cz
Posted: Wed Jun 15, 2022 3:21 pm
You can use something like this ( in block settings ):
i.e. substitute the unicode chars with:
&#xHHHH;
or
&#DDDD;
where HHHH is the hexadecimal representation of the unicode char
and DDDD is the decimal representation of the unicode char
Posted: Wed Jun 15, 2022 3:54 pm
by xBenny
Tricky but it works. Interestingly, I tried this before directly into a settings file and it didn't work. But through the block settings it works. Thanks
davidefa wrote: ↑Wed Jun 15, 2022 3:21 pm
&#xHHHH;
or
&#DDDD;
