Template, Meteobridge & database troubles
Posted: Sat Jul 17, 2021 8:51 pm
Good afternoon,
Weather data source - Ecowitt GW-1000
Meteotemplate data source - Meteobridge 5.2
PHP version on the server - 4.7
I noticed that my air quality block that used to receive PP1 data from my Meteobridge stopped reporting. After digging into my SQL server, I see the last time that the database received actual PP1 data was back in May. Odd, I thought it was working fine. At the same time, I see that the extra sensors table only includes Extra Temp & Humidity sensors 1-4, even though I have 5, and all 5 are reporting per my apilog file (and show up in my custom Extra Temp sensor block). Additionally, I have the Ecowitt lightning detector and I would like to get that work too. The live data tab on my Meteobridge shows all 5 extra temp sensors, the air quality sensor, and the lightning sensor.
Questions - anyone know why the Meteobridge would not be passing PP1 to the api.php file? It had been working fine until recently, now it doesn't.
I see elsewhere that Ecowitt has blocks for their devices, I downloaded those, along with the latest version of the Ecowitt plugin, and configured my GW-1000 via the WS View app on my Android phone per the instructions in the plugin. The csv file with weather data that should be created in the plugin folder is not being created, so that data source isn't working either.
Is there a log file other than what is in the cache file, or a way to enable more detailed log files? Maybe if I could see what the Meteobridge was trying to send to the api.php I could see if there is a problem there.
thx
Mike
thx
Mike
