Alert method if data is less greater than XX minutes old?
- Daali
is anyone using a method to see (email) if the feed has stopped to the website? I've been having some issues with my secondary network(meteobridge and gw1000 feeding website) and want to get a text(email) if the website data has stopped feeding.
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
WH41 PM2.5 Air Quality
WH45 PM2.5/10/Co2 Air Quality
WN34S Soil temperature
WH31SM Soil Moisture
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
Re: Alert method if data is less greater than XX minutes old?
In the meteotemplate control panel you can find 'Offline Notification' that should be what you are looking for
- Daali
Well thank you davidefa! That was certainly a lot easier than the ifttt webhook block I made last night LOL.
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
- Daali
too funny, I really made this harder than it needed to be.
- using cron-job.org, the notifications alert works as intended.
- Also, if you have ecowitt and are sending data to ecowitt.net, they have an alert process for offline stations.
- or you could go the crazy path and create a block that checks ./cache/apiLog.txt for aging and webhook IFTTT for notifications. LOL. You can see the madness here: https://github.com/Daali/meteotemplate_ ... data_alert
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
