site no images
androroz
- Station model: WS-2310 11STWC
site no images
I installed meteotemplate 18.0 on the server, created a Config file, when I open the site https://us5wac.com/indexDesktop.php, the image is not displayed. Please help.
- Daali
Re: site no images
Which PHP is running? I'd run the server check from the main setup.
Also, are you sure you have the baseURL set appropriately in the main setup?
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
WH41 PM2.5 Air Quality
WH45 PM2.5/10/Co2 Air Quality
WN34S Soil temperature
WH31SM Soil Moisture
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
Re: site no images
Yes you have someting wrong in the configuration file config.php
Check in the first lines you should have:
$path = '/template/';
( with the ending slash )
androroz
Re: site no images
Good afternoon David! Fixed / template to / template / didn't help. Have a look at the whole config.php please.
- config.rar
- (2.54 KiB) Downloaded 489 times
androroz
Re: site no images
David! Here is what was sent from the server. They didn't help anything else.
- no image.png (186.07 KiB) Viewed 8765 times
androroz
Re: site no images
Dear Daali! Installed version - php 5.6 It is possible to install another version.
Re: site no images
On the site us5wac,com you installed meteotemplate in the root directory so you should set the variable path to:
$path = '/';
NOTE
The config.php you attached is relative to the site www.dragana.lviv.in
$path = '/';
NOTE
- Daali
Re: site no images
5.6 is ok sir. I would leave that alone for now until we get the config.php working well
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
- Daali
Re: site no images
see davidefa's post:
in the Main Setup, here is my section, you need to modify yours based on the errors when you inspect with chrome:
or here: https://prnt.sc/1t01ewh
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
GW1000 gateway
WS68 Anemometer
WH40 Rain Gauge
WH32 Temp/Hum
WH57 Lightning
