site no images
Posted: Sun Sep 19, 2021 12:21 pm
by androroz
I installed meteotemplate 18.0 on the server, created a Config file, when I open the site
https://us5wac.com/indexDesktop.php, the image is not displayed. Please help.
Re: site no images
Posted: Sun Sep 19, 2021 5:05 pm
by Daali
Which PHP is running? I'd run the server check from the main setup.
Also, are you sure you have the baseURL set appropriately in the main setup?
Re: site no images
Posted: Sun Sep 19, 2021 11:07 pm
Yes you have someting wrong in the configuration file config.php
Check in the first lines you should have:
$path = '/template/';
( with the ending slash )
Re: site no images
Posted: Mon Sep 20, 2021 7:21 am
by androroz
Good afternoon David! Fixed / template to / template / didn't help. Have a look at the whole config.php please.
Re: site no images
Posted: Mon Sep 20, 2021 7:38 am
by androroz
David! Here is what was sent from the server. They didn't help anything else.
Re: site no images
Posted: Mon Sep 20, 2021 7:47 am
by androroz
Dear Daali! Installed version - php 5.6 It is possible to install another version.
Re: site no images
Posted: Mon Sep 20, 2021 4:38 pm
On the site us5wac,com you installed meteotemplate in the root directory so you should set the variable path to:
$path = '/';
NOTE
The config.php you attached is relative to the site
www.dragana.lviv.in
Re: site no images
Posted: Mon Sep 20, 2021 7:52 pm
by Daali
androroz wrote: ↑Mon Sep 20, 2021 7:47 am
5.6 is ok sir. I would leave that alone for now until we get the config.php working well
Re: site no images
Posted: Mon Sep 20, 2021 7:59 pm
by Daali
see davidefa's post:
in the Main Setup, here is my section, you need to modify yours based on the errors when you inspect with chrome:
or here:
https://prnt.sc/1t01ewh
