Minimum windvalues' time?
Posted: Mon Feb 07, 2022 7:09 am
by Julius
I see the max values for Wind and Gust are mentioned with the measured time below the km/h values,
but the minimum values are not showing their last measured time. I would prefer it if they would.
This is the | Avg | Max | Min | table block, but I forgot its name.
Re: Minimum windvalues' time?
Posted: Mon Feb 07, 2022 11:44 pm
Ok, I think you refer to the Station Data block. I'll add this too ( I'm already modifying the block )
Posted: Tue Apr 26, 2022 2:41 pm
by Julius
davidefa wrote: Mon Feb 07, 2022 11:44 pm Ok, I think you refer to the Station Data block. I'll add this too ( I'm already modifying the block )
Did you get around to adding this? I already have installed Station Data 10.4, but it's not there yet. Perhaps because enough time has not passed yet?
TIA!
Posted: Tue Apr 26, 2022 8:42 pm
Sorry, for the delay... you can try this version:
- added wind/gust min time
Posted: Wed Apr 27, 2022 7:46 pm
by Julius
davidefa wrote: Tue Apr 26, 2022 8:42 pm Sorry, for the delay... you can try this version:
Thanks! Only problem now is that it's no longer showing anything;
Screenshot 2022-04-26 at 23-56-22 Broekermeer Weer.png (25.21 KiB) Viewed 44542 times
What is the exact syntax for self coloring the speeds in block config?
Posted: Wed Apr 27, 2022 8:00 pm
I think you are referring to the windRose block:
- in 'speed definition' set the 'speed ranges' you want to define ( setting n values sets n+1 ranges )
- in 'define colors for each speed' set the n+1 colors ( one for each previously defined range )
WindRose no longer works..
Posted: Thu Apr 28, 2022 8:58 am
by Julius
davidefa wrote: Wed Apr 27, 2022 8:00 pm I think you are referring to the windRose block:
Still doesn't change the way it looks for me. Still as the image I posted before. I see no legend, no colors. Any idea what could cause this?
Screenshot 2022-04-28 at 11-07-32 Broekermeer Weer.png (22.83 KiB) Viewed 44529 times
Screenshot 2022-04-28 at 11-07-58 Broekermeer Weer.png (13.02 KiB) Viewed 44529 times
it's being tested here
Posted: Thu Apr 28, 2022 10:22 am
It seems correct to me... there is something I don't understand.
Please post the windRose folder zipped so I can give it a try in my test setup.
Posted: Thu Apr 28, 2022 1:09 pm
by Julius
davidefa wrote: Thu Apr 28, 2022 10:22 am It seems correct to me... there is something I don't understand.
https://weer.broekermeer.nl/wr.tar.gz
Posted: Thu Apr 28, 2022 10:00 pm
You have an old version of the dataLoader.php ( homepage/blocks/windRose/dataLoader.php ) file.
Delete it and copy the attached one.
Posted: Sun May 01, 2022 10:40 am
by Julius
Wow, thanks David! Really strange, I unpacked 1.4 in the windRose dir using midnight commander, but apparently not all files got overwritten..
Posted: Tue May 03, 2022 7:13 am
by Jolumarali
Hello David
Would you have an idea for this difference in total annual rainfall on your stationdata10.5 version?
thank you
Posted: Tue May 03, 2022 1:35 pm
ver 10.6
- corrected rain data truncated to int values
Posted: Tue May 03, 2022 4:30 pm
by Jolumarali
Perfect, thank you Davide
