new plugin chill hours
Post by davidefa » Wed Mar 02, 2022 12:40 am
ver 0.8
Preliminary release. A plugin derived from Growing Degree Days plugin ( similar look/usage ).
Useful for fruit trees growing.
ver 0.9
- added 'dynamic model' chill hours calculation
- corrected 'utah model' calculation
- added short explanation of methods
To add to your menu you can use the following:
Chill Hours|plugins/chillHours|plugins/chillHours/ch.png
chillHours_0.9g.zip
(35.59 KiB) Downloaded 650 times
chillHours_0.8.zip
(34.4 KiB) Downloaded 614 times
Re: new plugin chill hours
Post by alexvanuxem » Wed Mar 02, 2022 5:34 pm
Hi, thx,
copied the subfolder into my plugins, could do the create settings.
Is it the purpose that I enter two months, 3,10 for example, or only 1 (3)?
insterted the plugin into my menu weather, but doesn't popup?
model is in F only?
thx, and grtz
Alex
Post by davidefa » Wed Mar 02, 2022 10:26 pm
The wording in the plugin setup is wrong: you need to set only the starting month of the chilling season ( September or October in northern hemisphere ).
The original document reports temperature thresholds in °F, but you can have your data in °C or °F it will be converted automatically.
For the menu you can use the following setting:
Or to access directly: https://www.sint-katelijne-waver-meteo.be/template/plugins/chillHours/index.php
Uploaded an updated version ( with few corrections ).
Thanx for testing. As I don't have a test dataset to verify the calculation, I'm not 'super confident' of the results ( particularly for the newly added 'dynamic model' ).
Post by alexvanuxem » Thu Mar 03, 2022 1:01 pm
interesting stuff,
did some reading about it, but need to digg deeper,
as I could use this also in my allotment.
For the plugin to appear in the menu as a normal plugin, what do I need to do exactly?
(sorry I'm not a wizzkid when comes to php, but I 'm trying to, learn.
your new version seems to work with your tips, but did not verification until now.
thx
Post by davidefa » Thu Mar 03, 2022 2:00 pm
Edit your menu and add a line similar to the previously posted one ( in my case I added to submenu 'weather station' between degree days and growing degree days )
Post by alexvanuxem » Thu Mar 03, 2022 3:11 pm
thank you for your patience.....
johnathan
Station model: wh1080
Post by johnathan » Tue Apr 19, 2022 11:06 am
The employment outlook for software development is very bright. There are a variety of career paths open to software developers of all levels and interests https://mlsdev.com/blog/it-outsourcing-companies. A software developer is vital to nearly every industry. The software that helps our world work and sends our paychecks is what keeps it running smoothly. The employment outlook for software developers is strong and should only continue to improve. Here are some of the reasons why you should consider a career in this area.
