Extreme Block 1970
Posted: Mon Mar 28, 2022 11:20 am
by Saszalez
Hello. I have installed the "Extremes Block", and when looking at the list, the first minimum value of any of the variables is 0, registered on January 1, 1970. There is no value for that date; it is always 0. How can it be corrected?
Re: Extreme Block 1970
Posted: Mon Mar 28, 2022 12:49 pm
You can remove this erroneous data ( via the meteotemplate control panel ) database -> edit data and database -> edit data extra sensors, remove any data of 01/01/1970 ( it should be only one ).
If you have several of these wrong data it could be faster to remove them via phpmyadmin ( accessibkle via your hosting provider's control panel )
Posted: Mon Mar 28, 2022 6:14 pm
by Saszalez
I have looked where you have told me, and there is no data. Therefore, I cannot delete anything.
Posted: Mon Mar 28, 2022 9:17 pm
I see.
To pinpoint the problem you can try executing the following query ( in phpmyadmin ):
SELECT DayAvg, DATETIME
FROM (
SELECT DATETIME, AVG(T) AS DayAvg
FROM alldata
GROUP BY YEAR(DATETIME), MONTH(DATETIME), DAY(DATETIME)
ORDER BY DATETIME
) AS DailyMaxTable
ORDER BY DayAvg
LIMIT 10
This is the same query that is executed to retrieve minimum average temperature:
- extremes01.png (26.66 KiB) Viewed 6163 times
Posted: Mon Mar 28, 2022 10:26 pm
by Saszalez
If I run the code I get the following:
Posted: Tue Mar 29, 2022 9:28 am
I'd say you have a record on 1970-01-01
This query ( in phpmyadmin ) should return exactly 1 result:
SELECT * FROM `alldata` WHERE DateTime <= '2020-01-01 00:00:00'
And this query should delete it:
DELETE FROM `alldata` WHERE DateTime <= '2020-01-01 00:00:00'
Is always a good idea to make a backup of the database before executing these ( potentially destructive ) queries
