some problems with php8.1
- meteoesine
- Station model: Davis Pro2+
- Software: Meteobridge nano
hi,
justo for info, I tried to update the site to version 8.1 (with 8.0 MT does not work, boh).
maybe Davide already knows but there are some pages that don't work for me:
/pages/station:
climapeIndices.php
graph.php (monthly averages)
reportDaily.php
all PDF reports (daily/monthly/yearly) - (already fixed for version 8 (but on my side they don't work)
/metar/index.php
thanks in advance
/pages/station:
climapeIndices.php
reportDaily.php
/metar/index.php
thanks in advance
- Dehatter
- Station model: Ecowitt WH80
- Software: Ecowitt GW1000
Re: some problems with php8.1
Adding Station Diary and Climate to the list.
In general, it seems anything associated with a PDF fails.
www.MeckWeather.com
www.MeckWeather.com
- meteoesine
Ciao,
today I discovered that I had problems with the meteobridge: it was no longer recording data on the database. (restarted MB and everything restarted regularly)
But the problem arises that the offline notification does not work with php8.1:
The current block continues to show the current time and the icon in the footer is also green "online". (and obviously no notification email has be sent)
I noticed the anomaly from the stationStatus block (lastest version 5.1) which was correctly displaying offline.
to add to the to-do list
tnx
tnx
- ScreenShot01099.jpg (84.87 KiB) Viewed 40747 times
It seems working correctly on your site now
But the image you posted is indeed strange
After a blackout period, the indication at the bottom of the page goes 'online' after the first update of the meteotemplateLive.txt file while the stationStatus block goes 'online' after the first write in the database.
So it is possible, for a few minutes, to have the first indicator 'online' and the second 'offline'.
But the image you posted shows the stationStatus block 'offline' with the indication that the last database write occurred 4' 23" ago ( and this is not correct )
- meteoesine
Yes, it works but...
Note, however, that the image has been modified with paint to show you how at about 14:00 I discovered the problem before I restored everything.
Note the interruptions: from your screenshot of last night at 23:50 to now ,there has been other interruptions for a total of 125 minutes (almost every 2 hours there are holes of 30-45 minutes) VERY STRANGE, and no reports of offline.
it will be necessary to understand what causes these interruptions, whether to php8.1, or to meteobridge (but it never happened) or to something else.
and above all that it notifies the offline
- ScreenShot01106.jpg (15.27 KiB) Viewed 40735 times
- meteoesine
Another minor anomaly:
I noticed that since I set for php8.1 evapotranspiration does not report the value at 00:00 the next day
- ScreenShot01104.jpg (34.29 KiB) Viewed 40734 times
- ScreenShot01103.jpg (53.5 KiB) Viewed 40734 times
- ScreenShot01105.jpg (21.42 KiB) Viewed 40734 times
- meteoesine
established that it is not meteobridge that loses data
- ScreenShot01107.jpg (13.3 KiB) Viewed 40727 times
- ScreenShot01108.jpg (43.96 KiB) Viewed 40727 times
- lemimi
Hi there,
I seem to have had the same kind of problem, see the images below for the last 14,10 and 7 days.
My MeteoTemplate runs in PHP 7.4.
On August 11 in the evening, I reloaded a new WU API key.
It seems to work fine since
Have a nice day everyone... Michel
- meteoesine
why sometimes it displays meteobridge and other times ecowitt plugin?
Help! what is happening?
- ScreenShot01110.jpg (19.13 KiB) Viewed 40722 times
- ScreenShot01106.jpg (18.93 KiB) Viewed 40722 times
Try updating the api.php script with the attached one.
On line 47 it has a debug option activated ( logging of all calls in cache/apiReqLog.txt ).
Has also a fix in case meteotemplateLive.txt is malformed.
Please send me the meteobridge log 8:00-8:40 so I can take a look if it contains anything 'suspicious'
- api_php8.1.zip
- (11.92 KiB) Downloaded 1377 times
- meteoesine
now I try it
see the meteobridge log, since I restarted it yesterday afternoon.
last operation around 9:00 when I extrapolated the data to check the last missing 30 min
- ScreenShot01111.jpg (110.91 KiB) Viewed 40718 times
You are using your meteobridge ( calling api.php script directly ) and the ecowitt plugin ( that feeds only indoor T/H/P, soil moisture and lightning ), the stationData block shows the last software signature it finds, so it is normalmeteoesine wrote: ↑Tue Aug 16, 2022 7:34 am why sometimes it displays meteobridge and other times ecowitt plugin?
Help! what is happening? :shock: :shock:
I mean this logging ( in text form, if possible ):
The other log you posted shows that nothing strange was logged by the meteobridge
- meteoesine
in allegato
- standard-iso-202208160800-202208160840-min5.zip
- (477 Bytes) Downloaded 1198 times
- meteoesine
another hole of 30 min
offline e non manda più i dati a meteobridge
- ScreenShot01115.jpg (22.78 KiB) Viewed 40708 times
- ScreenShot01114.jpg (57.54 KiB) Viewed 40709 times
- ScreenShot01113.jpg (4.88 KiB) Viewed 40711 times
- meteoesine
it must be a problem due to php 8.1
as soon as I set to 7.4 everything started working again
- ScreenShot01117.jpg (5.92 KiB) Viewed 40707 times
- ScreenShot01116.jpg (18.99 KiB) Viewed 40707 times
- Dehatter
I believe if you are using the Ecowitt Plugin and the 'new' api, you should be using a service call to send a http: call to the api.
I might be wrong about that, but it does work for me.
- meteoesine
hello Tom,
I am always open to all alternatives
could you kindly send me the complete details and instructions of the events to be added in the meteobridge?
have you also set php 8.1?
But in the 'weather nets' I guess meteotemplate has to be removed, isn't it?
many thanks in advance
- ScreenShot01118.jpg (15.88 KiB) Viewed 40696 times
- Dehatter
Yes, I am using PHP 8.1.
I followed the directions from this thread: https://www.wxforum.net/index.php?topic=40447.0
The complete line to be entered is:
http://YOUR-SITE/yourpath-to-the-templa ... api.php?U=[epoch.1:]&T=[th0temp-lastval.1:]&TMX=[th0temp-max5:]&TMN=[th0temp-min5:]&H=[th0hum-lastval.1:]&P=[thb0seapress-lastval:1]&W=[wind0avgwind-lastval=kmh:1]&G=[wind0wind-lastval=kmh:1]&B=[wind0dir-lastval:1]&R=[rain0total-daysum:--]&RR=[rain0rate-lastval:1]&S=[sol0rad-lastval:2]&UV=[uv0index-lastval:1]&TIN=[thb0temp-lastval.1:]&HIN=[thb0hum-lastval.1:]&T1=[th1temp-lastval.1:]&H1=[th1hum-lastval.1:]&SM1=[th20hum-lastval.0:]&SM2=[th21hum-lastval.0:]&SM3=[th22hum-lastval.0:]&SM4=[th23hum-lastval.0:]&SM5=[th24hum-lastval.0:]&L=[lgt0energy-lastval.0:]&PP1=[air0pm-lastval:2]&PP2=[air1pm-lastval:2]&PASS=yourpassword
You have to remove any sensors you do not have.
At the bottom of the "Services" tab, you need to add a service. Select 'HTTP Request' then select 'Periodical" then click add service event.
You will now see a blank service event.
You need to pick your frequency to send and add your api call, then click save.
For your reference, this is mine.
http://www.meckweather.com/template/api.php?U=[epoch.1:]&T=[th0temp-lastval.1:]&TMX=[th0temp-max5:]&TMN=[th0temp-min5:]&H=[th0hum-lastval.1:]&P=[thb0seapress-lastval:1]&W=[wind0avgwind-lastval=kmh:1]&G=[wind0wind-lastval=kmh:1]&B=[wind0dir-lastval:1]&R=[rain0total-daysum:--]&RR=[rain0rate-lastval:1]&S=[sol0rad-lastval:2]&UV=[uv0index-lastval:1]&TIN=[thb0temp-lastval.1:]&HIN=[thb0hum-lastval.1:]&SM1=[th20hum-lastval.0:]&L=[lgt0total-dmax.0:]&LD=[lgt0dist-lastval.1:]<=[lgt0total-nonzerotime=epoch:]&PASS='password" <-Use your update password
Just so you know, there seems to be a bit a lag using this method as I do not think the MB device places as high a priority on these events - sometimes it will not report for a few seconds and then I get 3 in 10 secs - but overall, I am happy with the results.
Additionally, you are correct to remove Meteotemplate from the "Weather Networks" tab by clicking 'No Upload' and then save.
I do not see the api viewer plugin on your site, but if you use it - the software description would show EcowittNet not Meteobridge.
Good luck and ask any more question if you need to.
- Dehatter
Additionally, I have determined that rebooting my Meteobridge device dramatically increases the stability of the calls.
The logging shows 'ERROR 500 internal server error'.
It could be useful, if you have access to the error log on your server, if you could verify if there is any error in the script api.php
( access to the error log varies, depending on server, on one server of mine every directory has an 'error_log' file, on another there is an entry in the control panel ).
You may also try this version of api.php ( which has additional logging and also error logging in file cache/apiErrorLog.txt, I tested this feature in the last block I wrote )
- api_php8.1.zip
- (12.26 KiB) Downloaded 1096 times
- meteoesine
thank you very much Tom,
I followed your instructions and you have to say that it works, but...
most probably as I have a lot (maybe too much) events/FTP/and scripts, and as you say, it has a certain (strong) delay, with the execution of this additional event, there is more time when Meteotemplate is offline than the time it is operational.
This is not good for me
I'll go back to the old API with stable php 7.4 waiting for a solution
thanks again for your contribution
- meteoesine
grazie Davide per il tuo 'sbattimento'. grazie davvero.
l'ultima api che mi hai inviato non contiene gli extra sensori quindi ho ripristinato quella precedente
ho rimesso php 8.1 e ho attivato il log degli errori che era disabilitato.
stiamo a vedere
stiamo a vedere
hcorrin
- Station model: Davis VP2
my host has 8.1.9 on https://www.hc-iom.co.uk/template/indexDesktop.php
the summary block just has the spinning icon
on the forecast block the wxsim fails to load
i have the php8.0 updates on
when i tried to change the default forecast from wxsim to noyr via block setup in admin i got error 504 so that's not working the plugin setup ran ok
i had to do it by editing the settings file in that block manually
these run ok on php8.0.17 running on my synology unit http://ballaugh.no-ip.biz:59202/templat ... esktop.php
there are other issues but these will do to start with
- regarding the summary block here is an updated version (uses yr.no api v2, it is compatible with php 8.1, at leat on my test ): viewtopic.php?f=54&t=2278&p=11393&hilit ... ock#p11431
- regarding the forecast block try rerunning the setup, set 'field separator in latest.csv' and save
