Problem on "summary" block
Posted: Mon Jun 27, 2022 1:33 pm
by Meteofabro
hello.
I wanted to point out that on the "summary" block the forecast no longer works (if I remember correctly it was weekly) which I believe was taken from Dark Sky.
Has anyone solved the problem yet?
Re: Problem on "summary" block
Posted: Mon Jun 27, 2022 1:41 pm
Is in my 'todo' list ( if I remember correctly is derived from yr.no and hast to be updated to his v2 api )
Posted: Mon Jun 27, 2022 2:06 pm
by Meteofabro
let me know when you solve.
Posted: Thu Jul 07, 2022 10:03 pm
Updated the block.
v5.5
- forecasts: updated to yr.no api v2.0
v5.6
- forecasts: corrected temperature import
v5.7
- forecasts: corrected day capitalization ( en, us, de languages )
Api v2.0 does not contain the wind name, so it will not appear in forecast
Posted: Fri Jul 08, 2022 5:56 pm
by Jolumarali
Hello David
I have a problem with the temperature display (see image)
and thank you again for your work
Posted: Fri Jul 08, 2022 7:54 pm
I agree... 1027°C is too much even for global warming ; - )
Added updated version to previous post.
Posted: Sat Jul 09, 2022 4:54 am
by Jolumarali
Hello Davide
update done, correct temperature, no worries :oops:
thanks again
Posted: Thu Jul 21, 2022 12:22 pm
by Meteofabro
Thank you Davidefa. :D
Posted: Sat Jul 23, 2022 11:55 am
by Meteofabro
Hello Davidefa.
By adding the "Summary" block to the smartphone / mobile version of the meteotemplate, you have a strange formatting, causing the block to move the graphics of all the blocks beyond the right edge of the smartphone display, so they do not remain centered.
Is it possible to solve this problem?
This occurs only by adding the "Summary" block to the meteotemplate for mobile devices.
Thank you.
Posted: Sat Jul 23, 2022 12:48 pm
by Meteofabro
I have changed the menus of the block, they seem more appropriate to me. But I still haven't fixed the formatting of the menu items.
Example are the entries "Week", "Station" and "Tomorrow" are without separator space.
How can I solve the problem?
Posted: Wed Aug 24, 2022 8:29 am
Sorry forgot to check your question:
solution a) rotate your phone ( sorry, this is my preferred solution as I have to do nothing ; - )
solution b) we can arrange the 'selection tabs' as a 'drop down menu' ( as the key factor is the length of these tabs )
solution c) we have to define 'super short' tabs headings ( shorter than you did ex: "Oggi Ora, Set. Staz. Dom. Altro" ), not very clear in my opinion, but easy to do
